[postgis-users] Shp2pgsql-gui, Save to schema other than public?
Francois Hugues
hugues.francois at irstea.fr
Tue Apr 17 09:58:50 PDT 2012
Yes you could use alter table but I meant you should click on public, which is the default value, into the gui and set it to whatever you want.
Hug
-----Message d'origine-----
De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Ryan Dalton
Envoyé : mardi 17 avril 2012 17:30
À : postgis-users at postgis.refractions.net
Objet : [postgis-users] Shp2pgsql-gui, Save to schema other than public?
I see that I can run the command "ALTER TABLE [name] SET SCHEMA
[new_schema]" via SQL, is this what you are referring to? Or are you
suggesting an alternate way to "manually edit the schema" within the
GUI that I must not be seeing...?
Ryan
Did you try to edit manually the name of the shema ? That should be ok
and you can do the same to set the table name, geometry column and
srid.
Hug
I just got PostGIS 2.0 installed and was using the Shp2pgsql-gui to
load some shapefiles into the database. I have created a 'data'
schema where I was planning to store all of my imported data, but when
I use the shapefile import GUI, it does not appear as though there is
an option to specify which schema to load the data into, and it just
goes into 'public'.
Is it possible to load to an alternate schema, and am I just missing
something obvious? Maybe a future feature enhancement if not?
Thanks,
Ryan
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
