[postgis-users] help needed
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Fri Apr 20 10:09:10 PDT 2012
> I tried retrieving a raster img using the gdal_translate.
> The problem now is that the retrieve works fine when I export only one of the
> bands, but
> gives a seg err. when no such option is given.
You will have to report this to the GDAL mailing list.
> Secondly I wish to publish the raster data as a WCS . Does Geoserver support a
> PostGIS db
> for a raster source.
Support for PostGIS Raster in Geoserver is provided as an extension to Geotools. See this:
http://docs.geotools.org/latest/userguide/library/coverage/pgraster.html
I don't know the actual status of the project.
Pierre
