[postgis-users] Problem in installing Postgis2.0.0 in Windowsx64
Paragon Corporation lr at pcorp.us
Sat Apr 21 08:39:01 PDT 2012
Giannis,
Sorry about that.  What version os PostgreSQL are you running.
Do a
SELECT version();
 You may be running an early 64-bit install. If you are not running the
latest micro (9.1.3) you may  want to upgrade to a newer version of
PostgreSQL 9.1 64-bit or wait till our next packaging which we are doing
now.
I learned from the EDB folks when they ran into similar issues testing that
the first release of the 64-bits came with libxml2.dll, but then they later
switched to using
libxml2-2.dll because of openssl build issues.
We didn't package libxml2-2.dll with the 64-bit builds because we thought
all the 6-bit installs had them already.
Thanks,
Regina
http://www.postgis.us
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Giannis
Giakoumidakis
Sent: Friday, April 20, 2012 6:55 AM
To: Post GIS Users Discussion
Subject: [postgis-users] Problem in installing Postgis2.0.0 in Windowsx64
I have used postgis-pg91x64-setup-2.0.0-3.exe but the installation couln't
complete, there is a "Database installation of PostGIS functions failed: and
an "ERROR: could not load library "C:/Program
Files/PostgreSQL/9.1/lib/postgis-2.0.dll": The specified module could not be
found.". It creates the "template_postgis_20" at the pgAdmin though. I use
Postgresql 9.1. Any idea what could be the problem?  Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120421/4cec705c/attachment.html>
