[postgis-users] Problem in installing Postgis2.0.0 in Windowsx64
Giannis Giakoumidakis
ggiakoumidakis at yahoo.com
Sun Apr 22 09:01:26 PDT 2012
Thank you, I re-installed the latest postgresql and everything worked fine.
To: 'PostGIS Users Discussion' <postgis-users at postgis.refractions.net>
Sent: Saturday, April 21, 2012 6:39 PM
Subject: Re: [postgis-users] Problem in installing Postgis2.0.0 in Windowsx64
Giannis,
Sorry about that. What version os PostgreSQL are
you running.
Do a
SELECT version();
You may be running an early 64-bit install. If
you are not running the latest micro (9.1.3) you may want to upgrade to a
newer version of PostgreSQL 9.1 64-bit or wait till our next packaging which we
are doing now.
I learned from the EDB folks when they ran into similar
issues testing that the first release of the 64-bits came with libxml2.dll,
but then they later switched to using
libxml2-2.dll because of openssl build
issues.
We didn't package libxml2-2.dll with the 64-bit builds
because we thought all the 6-bit installs had them
already.
Thanks,
Regina
http://www.postgis.us
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Giannis Giakoumidakis
>Sent: Friday, April 20, 2012 6:55 AM
>To: Post GIS Users Discussion
>Subject: [postgis-users] Problem in installing Postgis2.0.0 in Windowsx64
>I have used postgis-pg91x64-setup-2.0.0-3.exe but the installation couln't complete, there is a "Database installation of PostGIS functions failed: and an "ERROR: could not load library "C:/Program Files/PostgreSQL/9.1/lib/postgis-2.0.dll": The specified module could not be found.". It creates the "template_postgis_20" at the pgAdmin though. I use Postgresql 9.1. Any idea what could be the problem? Thanks.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120422/8b94e356/attachment.html>
