[postgis-users] Question about the right installation of postgis 2.0.0
Giannis Giakoumidakis ggiakoumidakis at yahoo.com
Sun Apr 22 04:27:11 PDT 2012
The error message at the beggining is:
user at ubuntu:/usr/local/pgsql/share/contrib/postgis-2.0$ psql -d test -f postgis.sql
SET
BEGIN
psql:postgis.sql:69: ERROR:  could not access file "$libdir/postgis-2.0": No such file or directory
psql:postgis.sql:74: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:postgis.sql:81: ERROR:  current transaction is aborted, commands ignored until end of transaction block
etc.
I don't know what's wrong with that and i'm stuck here. I would appreciate any help!
I use Osgeo Live 5.5 that comes with postgresql 8.4 and i have installed also the 9.1 one.The databases in pgAdminIII uses 8.4.
To: Giannis Giakoumidakis <ggiakoumidakis at yahoo.com>
Sent: Friday, April 20, 2012 2:26 PM
Subject: Re: [postgis-users] Question about the right installation of postgis 2.0.0
On 20 April 2012 11:16, Giannis Giakoumidakis <ggiakoumidakis at yahoo.com> wrote:
> My pgAdminIII still uses postgresql 8.4, even though i've installed 9.1.
> Anyway, I follow instructions from "2.5. Create a spatially-enabled database
> on PostgreSQL lower than 9.1".
> When I get to the:
> "Now load the PostGIS object and function definitions into your database by
> loading the postgis.sql definitions file (located in [prefix]/share/contrib
> as specified during the configuration step).
> psql -d [yourdatabase] -f postgis.sql."
> I get many errors ending like:
> "psql:postgis.sql:6075: ERROR:  current transaction is aborted, commands
> psql:postgis.sql:6081: ERROR:  current transaction is aborted, commands
> ROLLBACK".
> Anyone has an idea about that?
Look at he first error message, that is relevant. All other messages
are the same (transaction abort).
When you say "still using 8.4", you mean you have 2 running instances
(8 and 9) ?
Nicolas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120422/b6bb5b4a/attachment.html>
