[postgis-users] Using shp2pgsql
Denis Rouzaud denis.rouzaud at gmail.com
Wed Apr 25 07:51:35 PDT 2012
You could output shp2pgsql to a SQL file, then use it in psql to see at
which line the error occurs.
On 04/25/2012 04:46 PM, Paul Maddock wrote:
> Dear all,
> I'm using the following code to transform a shapefile I have into a
> table and import it into my database:
> shp2pgsql -s 3754 ~/JOE/columbus/pole_region.shp columbus.pole_region
> | psql -h localhost -U postgres -p 5432 -d paul
> When it runs I have to put my password in for postgres (expected), and
> I get the following output:
> ERROR:  current transaction is aborted, commands ignored until end of
> transaction block
> transaction block
> transaction block
> transaction block
> transaction block
> transaction block
> transaction block
> transaction block
> transaction block
> transaction block
> transaction block
> transaction block
> transaction block
> The database paul is created and the schema columbus is created and is
> owned by postgres.
> What am I doing wrong?  Do I have to set datatypes?
> Thanks for the help,
> Paul
> *Paul A. Maddock*
> Mapping Technician
> IJUS LLC
> 560 Officenter Place
> Gahanna, OH 43230
> Cell: (513) 404-6476
> Description: Description: Home <http://www.ijus.net/index.html>
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120425/36165d33/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120425/36165d33/attachment.gif>
