[postgis-users] Differences between schemas on different servers
White, Richard Richard.White at infoterra-global.com
Thu Apr 26 08:06:11 PDT 2012
I need to compare the differences between 2 postgres database schemas.
The schemas are named the same but running on different servers and
should be the same.
I want to know if server_1.schema.table is different to
server_2.schema.table with regards to numbers of features in each table
and when the last transaction / update  took place on each table.
Thanks.
R.
Infoterra Ltd. Is part of the Astrium GEO-Information Services Division and a wholly owned subsidiary of Astrium, Europe's leading space systems and services specialist.
Disclaimer. The information contained in this e-mail and its attachments are confidential and intended only for the use of the named addressee(s). If you are not the intended addressee, please do not read, copy, use or disclose this message or its attachments. If you have received this message in error, please notify the sender immediately and delete or destroy all copies of this message and attachments in all media. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Infoterra Ltd and shall not form part of any binding agreement.
Infoterra Limited a company registered in England under number 2359955 and having its registered office at Atlas House, 41 Wembley Road, Leicester, LE3 1UT. VAT number GB 476 0468 27.
P Before printing, think about the environment
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120426/47392b7f/attachment.html>
