[postgis-users] crash on ST_Clip()
Stephen Crawford src176 at psu.edu
Thu Apr 26 08:50:09 PDT 2012
OK, before I try to assemble all the data, a couple more questions.  I
was finally able to access the logs and I see two errors:
LOG:  database system is ready to accept connections
LOG:  autovacuum launcher started
ERROR:  column "o_column" does not exist at character 39
STATEMENT:  select o_table_name, overview_factor, o_column, o_table_schema from raster_overviews where r_table_schema = 'public' and r_table_name =
'spring_ms' and r_column = 'rast'
ERROR 6: EPSG PCS/GCS code 105002 not found in EPSG support files.  Is this a valid
EPSG coordinate system?
LOG:  server process (PID 5497) was terminated by signal 11: Segmentation fault
LOG:  terminating any other active server processes
WARNING:  terminating connection because of crash of another server process
DETAIL:  The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
For the first error, there is indeed no column "o_column" in the
raster_overviews table.  There are also no records in the table it at
his point.
For the second error "code 105002 not found in EPSG support files",
this projection is one I created to match the grids we use.  I inserted
the definition in spatial_ref_sys.  It is also listed in the
raster_columns and geometry_columns tables  Is there somewhere else I
need to define it?  I have used this projection in postgis for at least
4 years now.
I also noted that topology is not installed, if that matters at all.
postgres 8.4.9
postgis_full_version
POSTGIS="2.0.0 r9605" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.6"
LIBJSON="UNKNOWN" RASTER
Thanks again,
Steve
On 4/25/2012 5:05 PM, Paul Ramsey wrote:
> In order to fix a problem, developers must reproduce it. What do we
> need to reproduce it: the offending SQL and the data itself. In ideal
> test cases the users can embed the data statically into a single SQL
> statement. In others they provide minimal versions of the offending
> tables. Try to make reproducing the problem as easy as possible for
> others, and the odds of it being fixed go up. Create a ticket with the
> SQL and description and attach your data to it.
> <http://trac.osgeo.org/postgis>
> P.
> On Wed, Apr 25, 2012 at 1:29 PM, Stephen Crawford<src176 at psu.edu>  wrote:
>> Well I tried the same query for just one of the tiles that I know intersects
>> the the_geom but it crashed.  Then i simplified it further by using just a
>> box instead of a multipolygon and it still crashed.
>> On 4/25/2012 3:22 PM, Paul Ramsey wrote:
>>> Find the exact geometry pair that is causing the crash and file a
>>> ticket. (Yes, disconnecting means the backend went boom, that's a
>>> crash).
>>> P
>>> On Wed, Apr 25, 2012 at 12:15 PM, Stephen Crawford<src176 at psu.edu>    wrote:
>>>> All,
>>>> I have a query which works on my desktop Windows (postgis2.0 RC) but
>>>> crashes
>>>> on Linux (postgis2.0 official release).  And by crash i mean disconnects
>>>> me
>>>> from the server.
>>>> INSERT INTO result_raster_table (observation_date, rast)
>>>> SELECT r.observation_date, ST_Clip(r.rast,g.the_geom,-9999) AS rast
>>>> FROM raster_table r, geom_table g
>>>> WHERE r.observation_date = '2012-03-09';
>>>> 'raster_table ' holds tiles, 187 of which make up one observation_date,
>>>> and
>>>> 'geom_table' is just one record, the union of ~23 Eastern US states.
>>>> Any thoughts?
>>>> Thanks,
>>>> Steve
>>>> Stephen Crawford
>>>> Center for Environmental Informatics
>>>> The Pennsylvania State University
>>>> src176 at psu.edu
>>>> 814.865.9905
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Stephen Crawford
>> src176 at psu.edu
>> 814.865.9905
Stephen Crawford
src176 at psu.edu
814.865.9905
