[postgis-users] crash on ST_Clip()
Bborie Park
bkpark at ucdavis.edu
Thu Apr 26 09:30:58 PDT 2012
Steve,
The o_column column doesn't exist in 2.0 but did at one time prior to
that. I'd guess you need to update the SQL API using
rtpostgis_upgrade_20_minor.sql.
As for your second error, I believe that that error message is being
kicked back from GDAL BUT it isn't the actual error that is causing the
segfault. Please look at ticket #1782 as I think you're hitting that
bug. I fixed that bug in r9649. You will want to try that revision
instead.
GDAL is correct when it responds saying that EPSG:105002 is not found as
105002 isn't a valid EPSG (epsg-registry.org).
-bborie
On 04/26/2012 08:50 AM, Stephen Crawford wrote:
> OK, before I try to assemble all the data, a couple more questions. I
> was finally able to access the logs and I see two errors:
> LOG: database system is ready to accept connections
> LOG: autovacuum launcher started
> ERROR: column "o_column" does not exist at character 39
> STATEMENT: select o_table_name, overview_factor, o_column,
> o_table_schema from raster_overviews where r_table_schema = 'public' and
> r_table_name =
> 'spring_ms' and r_column = 'rast'
> ERROR 6: EPSG PCS/GCS code 105002 not found in EPSG support files. Is
> this a valid
> EPSG coordinate system?
> LOG: server process (PID 5497) was terminated by signal 11:
> Segmentation fault
> LOG: terminating any other active server processes
> WARNING: terminating connection because of crash of another server process
> DETAIL: The postmaster has commanded this server process to roll back
> the current transaction and exit, because another server process exited
> abnormally and possibly corrupted shared memory.
> For the first error, there is indeed no column "o_column" in the
> raster_overviews table. There are also no records in the table it at
> his point.
> For the second error "code 105002 not found in EPSG support files",
> this projection is one I created to match the grids we use. I inserted
> the definition in spatial_ref_sys. It is also listed in the
> raster_columns and geometry_columns tables Is there somewhere else I
> need to define it? I have used this projection in postgis for at least
> 4 years now.
> I also noted that topology is not installed, if that matters at all.
> postgres 8.4.9
> postgis_full_version
> POSTGIS="2.0.0 r9605" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
> September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.6"
> LIBJSON="UNKNOWN" RASTER
> Thanks again,
> Steve
> On 4/25/2012 5:05 PM, Paul Ramsey wrote:
>> In order to fix a problem, developers must reproduce it. What do we
>> need to reproduce it: the offending SQL and the data itself. In ideal
>> test cases the users can embed the data statically into a single SQL
>> statement. In others they provide minimal versions of the offending
>> tables. Try to make reproducing the problem as easy as possible for
>> others, and the odds of it being fixed go up. Create a ticket with the
>> SQL and description and attach your data to it.
>> <http://trac.osgeo.org/postgis>
>> P.
>> On Wed, Apr 25, 2012 at 1:29 PM, Stephen Crawford<src176 at psu.edu> wrote:
>>> Well I tried the same query for just one of the tiles that I know
>>> intersects
>>> the the_geom but it crashed. Then i simplified it further by using
>>> just a
>>> box instead of a multipolygon and it still crashed.
>>> On 4/25/2012 3:22 PM, Paul Ramsey wrote:
>>>> Find the exact geometry pair that is causing the crash and file a
>>>> ticket. (Yes, disconnecting means the backend went boom, that's a
>>>> crash).
>>>> P
>>>> On Wed, Apr 25, 2012 at 12:15 PM, Stephen
>>>>> All,
>>>>> I have a query which works on my desktop Windows (postgis2.0 RC) but
>>>>> crashes
>>>>> on Linux (postgis2.0 official release). And by crash i mean
>>>>> disconnects
>>>>> me
>>>>> from the server.
>>>>> INSERT INTO result_raster_table (observation_date, rast)
>>>>> SELECT r.observation_date, ST_Clip(r.rast,g.the_geom,-9999) AS rast
>>>>> FROM raster_table r, geom_table g
>>>>> WHERE r.observation_date = '2012-03-09';
>>>>> 'raster_table ' holds tiles, 187 of which make up one
>>>>> observation_date,
>>>>> and
>>>>> 'geom_table' is just one record, the union of ~23 Eastern US states.
>>>>> Any thoughts?
>>>>> Thanks,
>>>>> Steve
>>>>> Stephen Crawford
>>>>> Center for Environmental Informatics
>>>>> The Pennsylvania State University
>>>>> src176 at psu.edu
>>>>> 814.865.9905
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> Stephen Crawford
>>> src176 at psu.edu
>>> 814.865.9905
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
