[postgis-users] crash on ST_Clip()
Stephen Crawford src176 at psu.edu
Thu Apr 26 10:55:39 PDT 2012
Bborie,
So are you saying these are minor errors and are not causing the crash?
Or do you think it could be causing the crash and I need to get r9649?
Thanks,
Steve
On 4/26/2012 12:30 PM, Bborie Park wrote:
> Steve,
> The o_column column doesn't exist in 2.0 but did at one time prior to
> that.  I'd guess you need to update the SQL API using
> rtpostgis_upgrade_20_minor.sql.
> As for your second error, I believe that that error message is being
> kicked back from GDAL BUT it isn't the actual error that is causing the
> segfault.  Please look at ticket #1782 as I think you're hitting that
> bug.  I fixed that bug in r9649.  You will want to try that revision
> instead.
> GDAL is correct when it responds saying that EPSG:105002 is not found as
> 105002 isn't a valid EPSG (epsg-registry.org).
> -bborie
> On 04/26/2012 08:50 AM, Stephen Crawford wrote:
>> OK, before I try to assemble all the data, a couple more questions.  I
>> was finally able to access the logs and I see two errors:
>> LOG:  database system is ready to accept connections
>> LOG:  autovacuum launcher started
>> ERROR:  column "o_column" does not exist at character 39
>> STATEMENT:  select o_table_name, overview_factor, o_column,
>> o_table_schema from raster_overviews where r_table_schema = 'public' and
>> r_table_name =
>> 'spring_ms' and r_column = 'rast'
>> ERROR 6: EPSG PCS/GCS code 105002 not found in EPSG support files.  Is
>> this a valid
>> EPSG coordinate system?
>> LOG:  server process (PID 5497) was terminated by signal 11:
>> Segmentation fault
>> LOG:  terminating any other active server processes
>> WARNING:  terminating connection because of crash of another server process
>> DETAIL:  The postmaster has commanded this server process to roll back
>> the current transaction and exit, because another server process exited
>> abnormally and possibly corrupted shared memory.
>> For the first error, there is indeed no column "o_column" in the
>> raster_overviews table.  There are also no records in the table it at
>> his point.
>> For the second error "code 105002 not found in EPSG support files",
>> this projection is one I created to match the grids we use.  I inserted
>> the definition in spatial_ref_sys.  It is also listed in the
>> raster_columns and geometry_columns tables  Is there somewhere else I
>> need to define it?  I have used this projection in postgis for at least
>> 4 years now.
>> I also noted that topology is not installed, if that matters at all.
>> postgres 8.4.9
>> postgis_full_version
>> POSTGIS="2.0.0 r9605" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
>> September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.6"
>> LIBJSON="UNKNOWN" RASTER
>> Thanks again,
>> Steve
>> On 4/25/2012 5:05 PM, Paul Ramsey wrote:
>>> In order to fix a problem, developers must reproduce it. What do we
>>> need to reproduce it: the offending SQL and the data itself. In ideal
>>> test cases the users can embed the data statically into a single SQL
>>> statement. In others they provide minimal versions of the offending
>>> tables. Try to make reproducing the problem as easy as possible for
>>> others, and the odds of it being fixed go up. Create a ticket with the
>>> SQL and description and attach your data to it.
>>> <http://trac.osgeo.org/postgis>
>>> P.
>>> On Wed, Apr 25, 2012 at 1:29 PM, Stephen Crawford<src176 at psu.edu>   wrote:
>>>> Well I tried the same query for just one of the tiles that I know
>>>> intersects
>>>> the the_geom but it crashed.  Then i simplified it further by using
>>>> just a
>>>> box instead of a multipolygon and it still crashed.
>>>> On 4/25/2012 3:22 PM, Paul Ramsey wrote:
>>>>> Find the exact geometry pair that is causing the crash and file a
>>>>> ticket. (Yes, disconnecting means the backend went boom, that's a
>>>>> crash).
>>>>> P
>>>>> On Wed, Apr 25, 2012 at 12:15 PM, Stephen
>>>>>> All,
>>>>>> I have a query which works on my desktop Windows (postgis2.0 RC) but
>>>>>> crashes
>>>>>> on Linux (postgis2.0 official release).  And by crash i mean
>>>>>> disconnects
>>>>>> me
>>>>>> from the server.
>>>>>> INSERT INTO result_raster_table (observation_date, rast)
>>>>>> SELECT r.observation_date, ST_Clip(r.rast,g.the_geom,-9999) AS rast
>>>>>> FROM raster_table r, geom_table g
>>>>>> WHERE r.observation_date = '2012-03-09';
>>>>>> 'raster_table ' holds tiles, 187 of which make up one
>>>>>> observation_date,
>>>>>> and
>>>>>> 'geom_table' is just one record, the union of ~23 Eastern US states.
>>>>>> Any thoughts?
>>>>>> Thanks,
>>>>>> Steve
>>>>>> Stephen Crawford
>>>>>> Center for Environmental Informatics
>>>>>> The Pennsylvania State University
>>>>>> src176 at psu.edu
>>>>>> 814.865.9905
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> Stephen Crawford
>>>> src176 at psu.edu
>>>> 814.865.9905
Stephen Crawford
src176 at psu.edu
814.865.9905
