[postgis-users] Problem enabling postgis (Mac OS)
António Rodrigues
n.marxco at gmail.com
Mon Aug 13 16:43:57 PDT 2012
I uninstalled everything (again) manually since the binaries I last used
(from http://postgresapp.com/) did not have any uninstaller.
I installed again the binaries from kyngchaos. Postgis is in
/usr/local/pgsql-9.1/share/contrib/postgis-2.0.
The question is: in order to create a Postgis extension inside my database,
when in pgadmin I create a new extension, there is no Postgis option. Can I
just copy what is in the Postgis-2.0 folder into
/usr/local/pgsql-9.1/share/extension ?
Thanks,
Pedro
On Mon, Aug 13, 2012 at 11:29 PM, William Kyngesburye <woklist at kyngchaos.com
> wrote:
> How did you remove Postgres?
> Were there any errors in the installation of PostGIS?
> On Aug 13, 2012, at 9:57 AM, António Rodrigues wrote:
> > Thanks for the reply.
> > I completely removed postgresql. Re-installed from
> PostgreSQL-9.1.4-1.dmg and PostGIS-2.0.1-1.dmg. Now there are no traces of
> postgis in /usr/local/pgsql-9.1. Is this normal?
> > One other thing, from what I read and sticking for now to the advice of
> enabling postgis using extensions, shouldn't the postgis sql stuff be here
> -> /usr/local/pgsql-9.1/share/extension, so that in pgadmin, choosing new,
> postgis would show up as an option?
> > Sorry if I'm missing something obvious.
> > Thanks,
> > Pedro
> > On Sun, Aug 12, 2012 at 4:51 AM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
> > On Aug 11, 2012, at 8:35 PM, António Rodrigues wrote:
> > > Hi list,
> > > I'm having problems enabling postgis on a mac running Mountain Lion.
> Most likely this is due to my absolute lack of experience with postgresql,
> but I've read the documentation, searched the web and so far, no luck.
> > > This is what I've done
> > > Installed GDAL_Complete-1.9.dmg, PostgreSQL-9.1.4-1.dmg and
> PostGIS-2.0.1-1.dmg from kyngchaos (in this order)
> > > During installation, I was not prompted for a postgres password, hence
> I had problems when connecting as user (role) postgres.
> > This is normal - no password is set for the postgres role on
> installation. Local connections to postgres are all allowed without a
> password, and no external connections are allowed at all, in the default
> configuration (pg_hba.conf), so it should work, but the readme suggests
> setting a password (especially if you install it on a shared computer).
> > > In pgadmin I created a new role as superuser.
> > > From PostGIS documentation, I tried (in the psql console plugin…
> > > (p.14 in PostGIS 2.0.0 Manual)
> > > createdb db1
> > > createlang plpgsql db1
> > > psql -d db1 -f postgis.sql
> > > psql -d db1 -f spatial_ref_sys.sql
> > > psql -d db1 -f postgis_comments.sql
> > > psql -d db1 -f rtpostgis.sql
> > > psql -d db1 -f raster_comments.sql
> > > psql -d db1 -f topology/topology.sql
> > > psql -d db1 -f topology/topology_comments.sql
> > > psql -d db1 -f legacy.sql
> > > Nothing new: no postgis functions...
> > > Then Using the psql console plugin I typed:
> > > (p. 15PostGIS 2.0.0 Manual)
> > > psql -d db -c "CREATE EXTENSION postgis;"
> > > psql -d db -c "CREATE EXTENSION postgis_topology;"
> > > Again no good.
> > The problem may be that without any user flag, psql uses your system
> login name to connect to postgres. If you don't setup your login name as a
> postgres role, you won't connect. You need to add to your psql connection:
> > -U postgres
> > or other role with full permissions on the DB (I don't think you need
> superuser perms, only the superfluous createlang step in the old method
> did).
> > note: stick with the extension method - easier to install and upgrade.
> > > Then I pasted the code in from postgis.sql (from
> \usr\…contrib\postgis2.0 directly in a sql window in pgadmin…
> > > I got the error message: "ERROR: could not access file
> "$libdir/postgis-2.0": No such file or directory"
> > > I am aware this is a newby kind of problem, and I apologize for that,
> but some help would be really really great.
> > > Thanks,
> > > Pedro
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > Theory of the Universe
> > There is a theory which states that if ever anyone discovers exactly
> what the universe is for and why it is here, it will instantly disappear
> and be replaced by something even more bizarrely inexplicable. There is
> another theory which states that this has already happened.
> > -Hitchhiker's Guide to the Galaxy 2nd season intro
> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120814/9ebd984f/attachment.html>
