[postgis-users] Problem enabling postgis (Mac OS)
William Kyngesburye
woklist at kyngchaos.com
Mon Aug 13 17:02:32 PDT 2012
On Aug 13, 2012, at 6:43 PM, António Rodrigues wrote:
> I uninstalled everything (again) manually since the binaries I last used (from http://postgresapp.com/) did not have any uninstaller.
OK, you used a different Postgres in the past, and uninstalled that (I've never heard of postgres.app, but it looks like a simple uninstall). It sounded like you tried uninstalling my Postgres.
> I installed again the binaries from kyngchaos. Postgis is in /usr/local/pgsql-9.1/share/contrib/postgis-2.0.
> The question is: in order to create a Postgis extension inside my database, when in pgadmin I create a new extension, there is no Postgis option. Can I just copy what is in the Postgis-2.0 folder into /usr/local/pgsql-9.1/share/extension ?
No, you can't copy share/contrib/postgis-2.0 files to share/extensions. It's very odd that you have no PostGIS extension files. Try reinstalling just PostGIS, and you don't need to uninstall anything.
> Thanks,
> Pedro
> On Mon, Aug 13, 2012 at 11:29 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> How did you remove Postgres?
> Were there any errors in the installation of PostGIS?
> On Aug 13, 2012, at 9:57 AM, António Rodrigues wrote:
> > Thanks for the reply.
> > I completely removed postgresql. Re-installed from PostgreSQL-9.1.4-1.dmg and PostGIS-2.0.1-1.dmg. Now there are no traces of postgis in /usr/local/pgsql-9.1. Is this normal?
> > One other thing, from what I read and sticking for now to the advice of enabling postgis using extensions, shouldn't the postgis sql stuff be here -> /usr/local/pgsql-9.1/share/extension, so that in pgadmin, choosing new, postgis would show up as an option?
> > Sorry if I'm missing something obvious.
> > Thanks,
> > Pedro
> > On Sun, Aug 12, 2012 at 4:51 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> > On Aug 11, 2012, at 8:35 PM, António Rodrigues wrote:
> > > Hi list,
> > > I'm having problems enabling postgis on a mac running Mountain Lion. Most likely this is due to my absolute lack of experience with postgresql, but I've read the documentation, searched the web and so far, no luck.
> > > This is what I've done
> > > Installed GDAL_Complete-1.9.dmg, PostgreSQL-9.1.4-1.dmg and PostGIS-2.0.1-1.dmg from kyngchaos (in this order)
> > > During installation, I was not prompted for a postgres password, hence I had problems when connecting as user (role) postgres.
> > This is normal - no password is set for the postgres role on installation. Local connections to postgres are all allowed without a password, and no external connections are allowed at all, in the default configuration (pg_hba.conf), so it should work, but the readme suggests setting a password (especially if you install it on a shared computer).
> > > In pgadmin I created a new role as superuser.
> > > From PostGIS documentation, I tried (in the psql console plugin…
> > > (p.14 in PostGIS 2.0.0 Manual)
> > > createdb db1
> > > createlang plpgsql db1
> > > psql -d db1 -f postgis.sql
> > > psql -d db1 -f spatial_ref_sys.sql
> > > psql -d db1 -f postgis_comments.sql
> > > psql -d db1 -f rtpostgis.sql
> > > psql -d db1 -f raster_comments.sql
> > > psql -d db1 -f topology/topology.sql
> > > psql -d db1 -f topology/topology_comments.sql
> > > psql -d db1 -f legacy.sql
> > > Nothing new: no postgis functions...
> > > Then Using the psql console plugin I typed:
> > > (p. 15PostGIS 2.0.0 Manual)
> > > psql -d db -c "CREATE EXTENSION postgis;"
> > > psql -d db -c "CREATE EXTENSION postgis_topology;"
> > > Again no good.
> > The problem may be that without any user flag, psql uses your system login name to connect to postgres. If you don't setup your login name as a postgres role, you won't connect. You need to add to your psql connection:
> > -U postgres
> > or other role with full permissions on the DB (I don't think you need superuser perms, only the superfluous createlang step in the old method did).
> > note: stick with the extension method - easier to install and upgrade.
> > > Then I pasted the code in from postgis.sql (from \usr\…contrib\postgis2.0 directly in a sql window in pgadmin…
> > > I got the error message: "ERROR: could not access file "$libdir/postgis-2.0": No such file or directory"
> > > I am aware this is a newby kind of problem, and I apologize for that, but some help would be really really great.
> > > Thanks,
> > > Pedro
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > Theory of the Universe
> > There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
> > -Hitchhiker's Guide to the Galaxy 2nd season intro
> "History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
All generalizations are dangerous, even this one.
