[postgis-users] Linear referencing capability
Melpati, Muni Muni.Melpati at dot.state.fl.us
Thu Aug 23 09:24:35 PDT 2012
In a shapefile, especially routes, you can have user defined measures (m-values, usually in miles), they might not be same when you measure the two dimenstional line, from  start to end vertices of any feature. These shapefiles would have begin and end post fields as attributes.
It is not the case for any shapefiles with line types since two dimensional measures deviate from real distance from point a to point b. Moreover they would not be in miles.
I was asking if I import a shapefile of "polyline M" into PostGIS would I be able to get measure in miles given a point or would I be able to get points given a measure in miles? Orelse there is different mechanism in PostGIS
to the same job. If so how it is done. I know there are few methods to retrieve a mile point or a measure give a point in PostGIS. Doesn't this require calibrating the route, first, like I found out in this link (http://www.faunalia.com/lrs). Sorry for not being very clear in my previous question. I thought people might have confounded this situation and can easily understand it. Please let me know if still do not understand or help me if you can.
Date: Tue, 21 Aug 2012 21:12:04 -0400
From: "Paragon Corporation" <lr at pcorp.us<mailto:lr at pcorp.us>>
Subject: Re: [postgis-users] created linear referencing system
To: "'PostGIS Users Discussion'"
      <postgis-users at postgis.refractions.net<mailto:postgis-users at postgis.refractions.net>>
Message-ID: <527D56A990434161A53D6CA92B3D9ED9 at O>
Content-Type: text/plain; charset="us-ascii"
Muni,
Not sure what you are asking and maybe others have a similar problem
understanding.  That might be why you haven't received an answer.
What do you mean by linear reference capable?  All spatial data that is of
linestrings can be linearly referenced.  Are you talking about a specific
tool you are using?
when you load your data from shape file to PostGIS, the data is still the
same.  If it had linestrings before, it should still have linestrings.
  _____
From: postgis-users-bounces at postgis.refractions.net<mailto:postgis-users-bounces at postgis.refractions.net>
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Melpati,
Muni
Sent: Tuesday, August 21, 2012 4:07 PM
To: postgis-users at postgis.refractions.net<mailto:postgis-users at postgis.refractions.net>
Subject: [postgis-users] created linear referencing system
I have asked this question before and could not get straight answer. I have
a shape file which Linear reference capable. How to import such data?
If I load the data using shape file loader, would the imported data is
linear reference capable. If not how to recreate linear referencing system
on imported data?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120823/811eaea6/attachment.html>
