[postgis-users] mac 10.8
William Kyngesburye
woklist at kyngchaos.com
Fri Aug 24 06:35:41 PDT 2012
I sounds like you might be mixing distributions - maybe stackbuilder Postgres + my PostGIS? If it's my PostGIS package, I only support my Postgres package.
On Aug 24, 2012, at 8:26 AM, Randy Horner wrote:
> When using one click install postgres 9.1.5 install for max 10.8 the stack builder installer does not list postgis 2.0. (only 1.5) When I install 1.5 it says it was installed successfully but nothing is put on the mac. No postgis.sql or anything. This happens on all of our mac books. When I try to run the postgis 2 install seperately, it says postgres 9.1 is required. (It is installed and running).
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
