[postgis-users] mac 10.8
William Kyngesburye
woklist at kyngchaos.com
Fri Aug 24 08:37:47 PDT 2012
On Aug 24, 2012, at 10:16 AM, Randy Horner wrote:
> I'm sure you are correct. A couple questions if you have the time:
> To uninstall a failed postgres/postgis, we stop the postgres service and delete any directories we find. Anything we are missing? How does the staker check for installed versions of postgres/postgis?
I don't know how stackbuilder works.
> Does installing gdal 1.9 Complete from your site satisfy the geos 3 and proj4 requirements for postgis? Only your distribution or anyone's distribution of postgis?
Everything needed is specified on my PostGIS page and is available on my site. Other PostGIS distributions may use my frameworks (GDAL, ...), but for something like stackbuilder or homebrew they usually do everything.
> Finally, we have many postgis 1.5.. database's on a windows servers. Should we be able to back them up and then restore them on a postgis 2.0 fresh install?
The PostGIS documentation has upgrade procedures, but basically yes - dump from 1.5, load into 2.0.
> Sorry for my ignorance, we love gis and postgres/postgis but our we are pretty new to the mac arena.
> And thanks for the quick reply. All of us appreciate your site and helpful work you do.
> -----Original Message-----
> From: William Kyngesburye [mailto:woklist at kyngchaos.com]
> Sent: Friday, August 24, 2012 8:36 AM
> To: PostGIS Users Discussion
> Cc: Randy Horner
> Subject: Re: [postgis-users] mac 10.8
> I sounds like you might be mixing distributions - maybe stackbuilder Postgres + my PostGIS? If it's my PostGIS package, I only support my Postgres package.
> On Aug 24, 2012, at 8:26 AM, Randy Horner wrote:
>> When using one click install postgres 9.1.5 install for max 10.8 the stack builder installer does not list postgis 2.0. (only 1.5) When I install 1.5 it says it was installed successfully but nothing is put on the mac. No postgis.sql or anything. This happens on all of our mac books. When I try to run the postgis 2 install seperately, it says postgres 9.1 is required. (It is installed and running).
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
