[postgis-users] a long time calculate distance between point and polygon
Francisco Salas
fsalas at pinar.geocuba.cu
Mon Dec 10 06:46:44 PST 2012
Hi, Nicklas , I used this
select * from pozos p,suelos s where ST_DWithin(p.the_geom,s.the_geom,1000)
but in the output panel Messages of the pgAdmin III , appear only this
around 22011 ms
********** Error **********
How I can determinate what's is the problems ?
Regards,
Francisco Salas
-----Mensaje original-----
De: postgis-users-bounces at lists.osgeo.org
[mailto:postgis-users-bounces at lists.osgeo.org] En nombre de Nicklas Avén
Enviado el: miércoles, 05 de diciembre de 2012 04:45 p.m.
Para: PostGIS Users Discussion
Asunto: Re: [postgis-users] a long time calculate distance between point and
polygon
Hallo
You should use ST_DWithin instead with gist index on your gometry/geography
column:
HTH
Nicklas
On Wed, 2012-12-05 at 16:32 -0500, Francisco Salas wrote:
> Hi,
> I have test in two database one with SRID 2085 an other 4326 use this
> sql
> pozos : 2339 rows
> suelos:1526 rows
> for 2085 :
> st_distance(p.the_geom,s.the_geom)
> <=1000
> time of result : 3 minutes aprox
> for 4326 :
> st_distance(p.the_geom,s.the_geom,true)
> <=1000
> time of result : not determined
> Why happen this problem?
> How I can optimize this?
> I am using PostGis 1.5.2
> Regards,
> Francisco Salas
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
