[postgis-users] a long time calculate distance between point and polygon
Nicklas Avén
nicklas.aven at jordogskog.no
Wed Dec 5 13:44:38 PST 2012
Hallo
You should use ST_DWithin instead with gist index on your
gometry/geography column:
select * from pozos p,suelos s where
ST_DWithin(p.the_geom,s.the_geom,1000)
HTH
Nicklas
On Wed, 2012-12-05 at 16:32 -0500, Francisco Salas wrote:
> Hi,
> I have test in two database one with SRID 2085 an other 4326 use this
> sql
> pozos : 2339 rows
> suelos:1526 rows
> for 2085 :
> st_distance(p.the_geom,s.the_geom)
> <=1000
> time of result : 3 minutes aprox
> for 4326 :
> st_distance(p.the_geom,s.the_geom,true)
> <=1000
> time of result : not determined
> Why happen this problem?
> How I can optimize this?
> I am using PostGis 1.5.2
> Regards,
> Francisco Salas
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
