[postgis-users] shp2pgsql error
Sandro Santilli
strk at keybit.net
Fri Dec 14 07:30:00 PST 2012
Sounds like you didn't run "sudo ldconfig" after install of 2.0.2.
Possible ?
--strk;
On Fri, Dec 14, 2012 at 10:06:37AM -0500, Jeff Lake wrote:
> just a follow up, I had to revert back to postGIS2.0.1 as this is a
> full production database server...
> interesting enough, this is the output from ldd /usr/bin/shp2pgsql
> quite the difference, both versions built with the same configure flag
> linux-vdso.so.1 => (0x00007fff4b3f8000)
> liblwgeom-2.0.1.so => /usr/local/lib/liblwgeom-2.0.1.so
> (0x00007fe6b2e9a000)
> libgeos_c.so.1 => /usr/lib64/libgeos_c.so.1 (0x00007fe6b2c75000)
> libproj.so.0 => /usr/lib64/libproj.so.0 (0x0000003633e00000)
> libc.so.6 => /lib64/libc.so.6 (0x0000003633a00000)
> libgeos-3.3.6.so => /usr/lib64/libgeos-3.3.6.so
> (0x00007fe6b28e2000)
> libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x0000003032200000)
> libm.so.6 => /lib64/libm.so.6 (0x0000003634600000)
> libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000003031600000)
> /lib64/ld-linux-x86-64.so.2 (0x0000003633600000)
> *Jeff Lake*
> MichiganWxSystem <http://www.michiganwxsystem.com>
> AllisonHouse <http://www.allisonhouse.com>
> GRLevelXStuff <http://www.grlevelxstuff.com>
> On 12/14/2012 9:20, Jeff Lake wrote:
> >I just upgraded my postGIS2.0.1 to 2.0.2 from source..
> >Now, I'm getting this error
> >shp2pgsql: error while loading shared libraries:
> >liblwgeom-2.0.2.so: cannot open shared object file: No such file
> >or directory
> >liblwgeom-2.0.2.so was found in /usr/local/lib/
> ># ldd /usr/bin/shp2pgsql
> > linux-vdso.so.1 => (0x00007fff27c5a000)
> > liblwgeom-2.0.2.so => not found
> >I must have missed a configure flag, but which one ??
> >*Jeff Lake*
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at lists.osgeo.org
> >http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
