[postgis-users] shp2pgsql error
Jeff Lake
jeff at michiganwxsystem.com
Fri Dec 14 07:41:30 PST 2012
I am root ...
besides, isn't needed when installing 2.0.1
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 12/14/2012 10:30, Sandro Santilli wrote:
> Sounds like you didn't run "sudo ldconfig" after install of 2.0.2.
> Possible ?
> --strk;
> On Fri, Dec 14, 2012 at 10:06:37AM -0500, Jeff Lake wrote:
>> just a follow up, I had to revert back to postGIS2.0.1 as this is a
>> full production database server...
>> interesting enough, this is the output from ldd /usr/bin/shp2pgsql
>> quite the difference, both versions built with the same configure flag
>> linux-vdso.so.1 => (0x00007fff4b3f8000)
>> liblwgeom-2.0.1.so => /usr/local/lib/liblwgeom-2.0.1.so
>> (0x00007fe6b2e9a000)
>> libgeos_c.so.1 => /usr/lib64/libgeos_c.so.1 (0x00007fe6b2c75000)
>> libproj.so.0 => /usr/lib64/libproj.so.0 (0x0000003633e00000)
>> libc.so.6 => /lib64/libc.so.6 (0x0000003633a00000)
>> libgeos-3.3.6.so => /usr/lib64/libgeos-3.3.6.so
>> (0x00007fe6b28e2000)
>> libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x0000003032200000)
>> libm.so.6 => /lib64/libm.so.6 (0x0000003634600000)
>> libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000003031600000)
>> /lib64/ld-linux-x86-64.so.2 (0x0000003633600000)
>> *Jeff Lake*
>> On 12/14/2012 9:20, Jeff Lake wrote:
>>> I just upgraded my postGIS2.0.1 to 2.0.2 from source..
>>> Now, I'm getting this error
>>> shp2pgsql: error while loading shared libraries:
>>> liblwgeom-2.0.2.so: cannot open shared object file: No such file
>>> or directory
>>> liblwgeom-2.0.2.so was found in /usr/local/lib/
>>> # ldd /usr/bin/shp2pgsql
>>> linux-vdso.so.1 => (0x00007fff27c5a000)
>>> liblwgeom-2.0.2.so => not found
>>> I must have missed a configure flag, but which one ??
>>> *Jeff Lake*
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121214/65f58bcf/attachment.html>
