[postgis-users] constraint issue in 2.0.2 r10789
Nicolas Ribot nicolas.ribot at gmail.com
Sat Dec 15 08:25:14 PST 2012
(sorry Hugues, did not see your answer... 0_o)
On 15 December 2012 17:23, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
> Hi,
> By calling AddGeometryColumn('public', profiles_line_wgs84', 'geom',
> 4326, 'LINESTRING', 2), Postgis 2.0 created a geometry column of type geometry(LineString,4326)
> that restrict that column to LINESTRINGs only.
> The constraint defined later does not change this restriction.
> To enable the older constraint mechanism (and define the geom column type
> as 'geometry'), call addGeometryColumn with 'false' as final parameter (
> http://postgis.refractions.net/docs/AddGeometryColumn.html).:
> SELECT AddGeometryColumn('public', 'profiles_line_wgs84', 'geom', 4326,
> 'LINESTRING', 2, false);
> By the way, do you really need to store heterogenous geometries ? It may
> prevent you from using some functions that will not handle both types.
> A trigger on the geom column could convert LINESTRINGs to MULTI by calling
> st_multi. ;)
> Nicolas
> On 15 December 2012 12:48, Gery . <gamejihou at hotmail.com> wrote:
>>  Hello,
>> I recently upgraded both my postgresql (from 8.4.4 to 9.2.2) and postgis
>> (from 1.5.3 to 2.0.2 r10789). With the previous versions I run thesecommands without problems:
>> [code]
>> CREATE TABLE profiles_line_wgs84(
>> GID SERIAL,
>> ID SMALLINT,
>> FID SMALLINT,
>> SURVEY VARCHAR(100),
>> PROFILE VARCHAR(100),
>> TYPE VARCHAR(100),
>> SOURCE VARCHAR(100),
>> NR_TRACES VARCHAR(100),
>> TRACE_SPACE_M VARCHAR(100),
>> LENGTH_M FLOAT,
>> COMMENTS TEXT
>> SELECT AddGeometryColumn('public', profiles_line_wgs84', 'geom', 4326,
>> 'LINESTRING', 2);
>> CREATE INDEX profiles_line_wgs84_geom ON profiles_line_wgs84 USING GIST (
>> geom );
>> ALTER TABLE profiles_line_wgs84 DROP CONSTRAINT enforce_geotype_geom;
>> ALTER TABLE profiles_line_wgs84 ADD CONSTRAINT enforce_geotype_geom CHECK
>> ((geometrytype(geom) = ANY (ARRAY['MULTILINESTRING'::text,
>> 'LINESTRING'::text])) OR geom IS NULL);
>> [/code]
>> now with postgis 2.0.2 I get these errors:
>> [code]
>> CREATE TABLE
>> addgeometrycolumn
>>  public.seismic_profiles_line_wgs84.geom SRID:4326 TYPE:LINESTRING DIMS:2
>> (1 row)
>> CREATE INDEX
>> psql:13_seismic_profiles_mergecsvshp2line.sql:119: ERROR:  constraint
>> "enforce_geotype_geom" of relation "profiles_line_wgs84" does not exist
>> psql:13_seismic_profiles_mergecsvshp2line.sql:128: ERROR:  Geometry type
>> (MultiLineString) does not match column type (LineString)
>> [/code]
>> it seems  to me that the constraint statement is ok, or is it something
>> missing? any idea is appreciated,
>> Thanks in advance,
>> Best regards,
>> __________________________________________________________________________________________
>> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si
>> NO es necesario.
>> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
>> Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken
>> Sie NICHT, wenn es NICHT notwendig ist.
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121215/b31cc20f/attachment-0001.html>
