[postgis-users] constraint issue in 2.0.2 r10789
Nicolas Ribot
nicolas.ribot at gmail.com
Mon Dec 17 07:36:17 PST 2012
If data contain both LINESTRING and MULTILINESTRING, then you should use
the MULTILINESTRING constraint. (this is the default shp2pgsql behavior, as
you noted).
Concerning the trigger, this is a 2 step operation:
First you create the function the trigger will call
Then you create a trigger on a table using this function:
-- function definition
create or replace function forceMulti() returns trigger as $$
DECLARE
BEGIN
NEW.geom := st_multi(NEW.geom);
RETURN NEW;
END;
$$ LANGUAGE PLPGSQL;
-- then trigger creation
create trigger forceMulti_trigger
BEFORE UPDATE OR INSERT
ON profiles_line_wgs84
FOR EACH ROW
EXECUTE PROCEDURE forceMulti();
insert into profiles_line_wgs84 (geom)
values ('srid=4326;LINESTRING(0 0, 1 1)'::geometry);
select st_astext(geom) from profiles_line_wgs84;
Nicolas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121217/fc16107f/attachment.html>
