[postgis-users] PostGIS 2.0 instalation problem
Willy-Bas Loos
willybas at gmail.com
Thu Dec 20 02:40:28 PST 2012
Hi Regina, thanks for answering
The compressed file that i was talking about was the postgis installation
executable (i just asked 7zip to unzip it and it worked)
I tried installing a newer version too (9.2 + postgis 2.0.1), but that
doesn't help.
I also tried the binaries that you suggested, but that doesn't help either.
Postgis 1.4 is the latest version that was installed successfully on this
PC. It was deinstalled before i installed this newer version.
1) i rebooted but that doesn't help
2) that's service Pack 3
3) The virus software is called "Symantec Endpoint Protection"
Cheers,
Willy-Bas
On Wed, Dec 19, 2012 at 4:33 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Well I tried it on a windows xp 32-bit. It was running 9.1.4 2.0.0. So
> first upgraded to 2.0.1 via stackbuilder (it did give me a failure) which
> was odd. Then upgraded to 9.1.7 and my 2.0.1 for some reason was fine then.
> To rule out issue with a clean 9.1.7 and postgis overwriting binaries I
> uninstalled 9.1.7 and postgis (whiche required reboot) , deleted the whole
> PostgreSQL folder, reinstalled 9.1.7, then 2.0.1 via stackbuilder. All
> seemed to go fine.
> It's possible I have something else installed on this machine it's using,
> but it does rule out XP alone being an issue.
> 1) Did you try rebooting your pc afterward?
> 2) Which service pack are you running on windows xp.
> 3) What virus software -- I've seen for example (I think it was Norton)
> delete some postgresql files on one machine thus preventing postgresql from
> starting.
> Hope that helps,
> Regina
> *From:* Willy-Bas Loos [mailto:willybas at gmail.com]
> *Sent:* Tuesday, December 18, 2012 11:30 AM
> *To:* PostGIS Users Discussion; Paragon Corporation
> *Subject:* Re: [postgis-users] PostGIS 2.0 instalation problem
> Hi,
> I have the same problem.
> I installed postgres on an XP PC, which worked fine. (PostgreSQL 9.1.7,
> compiled by Visual C++ build 1500, 32-bit)
> Then I used the StackBuilder to install PostGIS 2.
> Upon creating the extension, i get the error "ERROR: could not load
> library "C:/Program Files/PostgreSQL/9.1/lib/postgis-2.0.dll": unknown
> error 998"
> The same happens when executing the sql "create extension postgis;"
> I tried pasting the contents from the bin folder from the compressed
> postgis installation file into ../9.1/bin/, but to no avail.
> I used Depends.exe to diagnose, like Paragon suggested.
> I included the dwi-file as an attachment.
> Is there anything i can do?
> Cheers,
> WBL
> On Sat, May 19, 2012 at 2:50 AM, wobo <mcwobo at hotmail.com> wrote:
>> So, I've been trying to install PostGIS 2.0 over and over again on several
>> different Windows XP computers, but didn't succeed in getting it up and
>> running. So I ended up borrowing my brother's Windows 7 pc, using the
>> exact
>> same download (postgreSQL + postgis using stackbuilder) which took me
>> about
>> 5 minutes to succesfully install the whole thing.
>> I have no clue why it doesn't work on my XP. More exactly, why it can't
>> find
>> the correctly located postgis-2.0.dll-file. But at least I'll be able to
>> test and recap the 'PostGIS in Action' on Windows 7 from now on.
>> Many thanks for suggesting and helping anyway.
>> View this message in context:
>> http://postgis.17.n6.nabble.com/PostGIS-2-0-instalation-problem-tp4624902p4993596.html
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> "Quality comes from focus and clarity of purpose" -- Mark Shuttleworth
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121220/615f9a9a/attachment-0001.html>
