[postgis-users] Installing a fully functional PostGIS 2.0 on
Mathieu Basille
basille at ase-research.org
Mon Feb 6 16:33:48 PST 2012
I agree with the preceding message. On Debian Squeeze, to get an
operational GDAL, I need to edit the ldconfig configuration after the
installation from source of GDAL. Here is how I proceed:
# At first:
/sbin/ldconfig -p | grep gdal
# shows nothing...
# Checkt that GDAL libraries are in /usr/local/lib/:
find /usr -name libgdal.so.1
# And add it to the ld.so.conf, as root:
echo '/usr/local/lib' >> /etc/ld.so.conf
ldconfig
# Now:
# should give you something like that:
libgdal.so.1.9.0 (libc6) => /usr/local/lib/libgdal.so.1.9.0
libgdal.so.1 (libc6) => /usr/local/lib/libgdal.so.1
libgdal.so (libc6) => /usr/local/lib/libgdal.so
Mathieu.
Le 06/02/2012 19:26, Ing. Ramon Resendiz a écrit :
> My friend,
> Seems that you need edit your ldconfig configuration file (most of times locates on /etc directory) to point where is located your missing file at moment to compile, afer ran the command ldconfig, and then try to recompile again.
> Let me know if this work for you best regards,
> RR
> Enviado a través de BlackBerry de movistar
> Ing. Ramon Resendiz
> -----Original Message-----
> From: THX1138<ap.joseph at live.com>
> Sender: postgis-users-bounces at postgis.refractions.net
> Date: Mon, 6 Feb 2012 16:22:12
> To:<postgis-users at postgis.refractions.net>
> Reply-To: PostGIS Users Discussion<postgis-users at postgis.refractions.net>
> Subject: Re: [postgis-users] Installing a fully functional PostGIS 2.0 on
> Nearly two months later I still have not yet figured out how to get
> everything working. I have managed to install postgis 2.0 and get it working
> but without topology and raster support which is most of the new
> functionality.
> GDAL simply will not cease to produce errors about being unable to locate
> files (described at bottom of post)
> The following describes my EXACT process fresh after system install and
> application of updates on Ubuntu 11.10 64bit.
> --postgres install--
> sudo apt-get update
> sudo apt-get install build-essential
> sudo apt-get install python-dev libreadline-dev
> sudo apt-get install postgresql-9.1 postgresql-server-dev-9.1
> postgresql-contrib-9.1 postgresql-plpython-9.1
> --postgres setup--
> sudo passwd postgres
> sudo -u postgres psql postgres
> #enter password twice on prompts
> [in psql prompt]
> \password postgres
> --pgadmin setup--
> #You need to install a current version of pgadmin from launchpad in order to
> for it to be of use!
> sudo add-apt-repository ppa:rhonda/pgadmin3
> sudo gedit /etc/apt/sources.list.d/rhonda-pgadmin3-oneiric.list
> [in gedit replace "oneric" with "natty" on the following lines]
> deb http://ppa.launchpad.net/rhonda/pgadmin3/ubuntu oneiric main
> deb-src http://ppa.launchpad.net/rhonda/pgadmin3/ubuntu oneiric main
> #update repository and install
> sudo apt-get update
> sudo apt-get install pgadmin3=1.14.0~beta1-1~ppa1~natty1
> #to install server instrumentation, just click "fix it" on the message that
> pops up when you connect to server
> #edit pg_hba.conf to add connections and disable password prompting.
> sudo gedit /etc/postgresql/9.1/main/pg_hba.conf
> [in gedit change the uncommented methods for connections to "trust" for
> local,IPv4,IPv6; for any IPs you want to connect append the following to the
> bottom of the file for each ip you want to connect:
> host all all [ip address here]/32 trust
> #edit postgresql.conf
> sudo gedit /etc/postgresql/9.1/main/postgresql.conf
> #un-comment and change 'localhost' to '*' on the following line
> #listen_addresses = 'localhost' ==> listen_addresses = '*'
> --install proj--
> sudo apt-get install libproj-dev proj-bin
> --install geos--
> sudo apt-get install swig php5-dev phpunit
> cd /home/zoa3
> mkdir gis
> cd gis
> mkdir geos
> cd geos
> wget http://download.osgeo.org/geos/geos-3.3.2.tar.bz2
> tar xjvf geos-3.3.2.tar.bz2
> cd geos-3.3.2
> ./configure --enable-python --enable-php
> make
> sudo make install
> sudo ldconfig
> --prepare gdal--
> cd /home/zoa3/gis
> #download filegeodatabase api from
> http://resources.arcgis.com/content/geodatabases/10.0/file-gdb-download
> #copy filegeodatabase api to gis folder
> tar xzvf FileGDB_API_1_1-64.tar.gz
> sudo apt-get install subversion
> svn checkout https://svn.osgeo.org/gdal/trunk/gdal gdal
> cd /home/zonability3/gis/gdal
> svn update
> sudo apt-get install openjpeg-tools libopenjpeg-dev
> sudo apt-get install libpoppler13 libpoppler-dev (note different version
> than in instructions)
> sudo apt-get install expat libexpat1-dev libkml-dev libxerces-c-dev
> sudo apt-get install libcurl4-openssl-dev
> cd /home/zoa3/gis
> mkdir mdb
> cd mdb
> #download and move jackcess-1.2.2.jar into mdb
> (http://sourceforge.net/projects/jackcess/files/jackcess/1.2.2/jackcess-1.2.2.jar/download)
> wget
> http://apache.deathculture.net//commons/lang/binaries/commons-lang3-3.1-bin.tar.gz
> wget
> http://apache.cs.utah.edu//commons/logging/binaries/commons-logging-1.1.1-bin.tar.gz
> tar xzvf commons-lang3-3.1-bin.tar.gz
> tar xzvf commons-logging-1.1.1-bin.tar.gz
> sudo cp commons-logging-1.1.1/commons-logging-1.1.1.jar
> commons-lang3-3.1/commons-lang3-3.1.jar jackcess-1.2.2.jar
> /usr/lib/jvm/java-6-openjdk/jre/lib/ext
> --install gdal--
> cd /home/zoa3/gis/gdal
> ./configure \
> --with-python --with-poppler \
> --with-pg \
> --with-curl \
> --with-openjpeg --with-geos --with-geotiff \
> --with-jpeg --with-png \
> --with-expat --with-libkml --with-xerces-c \
> --with-java=/usr/lib/jvm/java-1.6.0-openjdk/ --with-mdb \
> --with-fgdb=/home/zoa3/gis/FileGDB_API
> make
> sudo make install
> sudo ldconfig
> =======================================Errors============================================
> ---------------------Error1:
> Found when using open jdk 7 (installed with sudo apt-get install
> openjdk-7-jdk)
> ./configure \
> --with-pg \
> --with-curl \
> --with-java=/usr/lib/jvm/java-1.7.0-openjdk-amd64 --with-mdb \
> --with-fgdb=/home/zonability3/gis/FileGDB_API
> I receive the following messages:
> zoa3 at ZB3:~$ gdalinfo --version
> gdalinfo: error while loading shared libraries: libjvm.so: cannot open
> shared object file: No such file or directory
> When I try to locate that file I get the following results:
> zoa3 at ZB3:~$ locate libjvm.so
> /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/cacao/libjvm.so
> /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/jamvm/libjvm.so
> /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/server/libjvm.so
> --------------------------------Error2
> Using jdk 6 which was apparently preinstalled as I found out when I used
> locate in my previous try and fails on configure.
> ./configure \
> --with-pg \
> --with-curl \
> checking for location of Python Makefiles... found
> checking where to install Python modules...
> /usr/lib64/python2.7/site-packages
> enabled
> checking for python setuptools... not found
> checking whether we should include Java support... configure: error: "Cannot
> find /usr/lib/jvm/java-1.6.0-openjdk//include directory."
> Error3:--------------
> Trying to save myself the 11th reinstall of my entire system (as source gdal
> 1.9 has no uninstall functionality) I ran this without the java and mdb
> line.
> it configured properly but then gave me the following when I tried to test
> it:
> zoa3 at ZB3:~/gis/gdal$ gdalinfo --version
> gdalinfo: error while loading shared libraries: libFileGDBAPI.so: cannot
> open shared object file: No such file or directory
> Please let me know if you have any idea what might be wrong!
> View this message in context: http://postgis.17.n6.nabble.com/Installing-a-fully-functional-PostGIS-2-0-on-Ubuntu-Linux-GEOS-GDAL-issues-tp3566227p4371098.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
~$ whoami
Mathieu Basille, Post-Doc
~$ locate
Laboratoire d'Écologie Comportementale et de Conservation de la Faune
+ Centre d'Étude de la Forêt
Département de Biologie
Université Laval, Québec
~$ info
http://ase-research.org/basille
~$ fortune
``If you can't win by reason, go for volume.''
Calvin, by Bill Watterson.
