[postgis-users] Keeping vertices from lines in order... .
Stephen V. Mather
svm at clevelandmetroparks.com
Thu Feb 9 12:57:52 PST 2012
Hi All,
If I'm converting from a line to its vertices, I use
something like this (ala the postgis docs):
SELECT
ST_PointN(
the_geom,
generate_series(1, ST_NPoints(the_geom))
FROM ms_trails_test AS foo;
Now, if I want to make sure I keep all those vertices in order for later, I
better give them an id, so here's my original cludge:
SELECT
ST_PointN(
the_geom,
generate_series(1, ST_NPoints(the_geom)) + foo.gid * 100000
Which is fine for most cases, but not really a general solution. .
Better yet, I'll just keep my original gid as the feature id and have a
separate vertex id:
SELECT
ST_PointN(
the_geom,
gid as feature_id,
generate_series(1, ST_NPoints(the_geom)) as vertex_id
Thus, I can play with the points and reassemble them back into lines later.
But, it seems inefficient to run generate_series twice. Is this the best
way?
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
<http://www.clemetparks.com/> clevelandmetroparks.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120209/13be7896/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120209/13be7896/attachment.png>
