[postgis-users] Keeping vertices from lines in order... .
Nicolas Ribot
nicolas.ribot at gmail.com
Thu Feb 9 13:40:06 PST 2012
The new st_dumppoints() function may be useful in your case. It returns an
array of (path, point) that represents the line vertices:
select st_dumppoints('LINESTRING(0 0, 1 1, 2 2)'::geometry);
st_dumppoints
({1},010100000000000000000000000000000000000000)
({2},0101000000000000000000F03F000000000000F03F)
({3},010100000000000000000000400000000000000040)
(3 rows)
Nicolas
On 9 February 2012 21:57, Stephen V. Mather <svm at clevelandmetroparks.com>wrote:
> Hi All,****
> If I’m converting from a line to its vertices, I use
> something like this (ala the postgis docs):****
> SELECT ****
> ST_PointN(****
> the_geom,****
> generate_series(1, ST_NPoints(the_geom))****
> FROM ms_trails_test AS foo;****
> Now, if I want to make sure I keep all those vertices in order for later,
> I better give them an id, so here’s my original cludge:****
> SELECT ****
> ST_PointN(****
> the_geom,****
> generate_series(1, ST_NPoints(the_geom)) + foo.gid * 100000
> Which is fine for most cases, but not really a general solution… .****
> Better yet, I’ll just keep my original gid as the feature id and have a
> separate vertex id:****
> SELECT ****
> ST_PointN(****
> the_geom,****
> gid as feature_id,****
> generate_series(1, ST_NPoints(the_geom)) as vertex_id****
> Thus, I can play with the points and reassemble them back into lines
> later. But, it seems inefficient to run generate_series twice. Is this
> the best way?****
> **[image: http://www.clemetparks.com/images/esig/cmp-ms-90x122.png]**Stephen
> Mather
> Geographic Information Systems (GIS) Manager
> (216) 635-3243****
> clevelandmetroparks.com <http://www.clemetparks.com/>****
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120209/48a6329b/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120209/48a6329b/attachment.png>
