[postgis-users] Installing raster in POSTGIS 2.0
Bborie Park bkpark at ucdavis.edu
Fri Feb 10 07:07:17 PST 2012
You'll need to provide significantly more information about the errors
than you're currently providing.
The messages similar to "spheroid does not exist" are probably NOTICEs
and are expected due to the chicken-egg problem relating to TYPEs.
Specifically, we need to see what are the other errors when you
attempt to load postgis.sql.  If postgis.s
On Fri, Feb 10, 2012 at 6:57 AM, Mathieu Basille
<basille at ase-research.org> wrote:
> Are these ERROR messages or simple NOTICE? It might be working despite the
> messages... Sorry I can't help more. I used it a couple of months ago
> without any problems, but I guess things changed since then (as I understand
> from the modification of file locations).
> It seems more a problem of PostGIS developers than users now. Please keep
> the list informed about your progress, as it would be very valuable
> information for people using Debian-based distributions.
> Best of luck,
> Mathieu.
> Le 10/02/2012 09:45, nikhil a écrit :
>> Hi,
>> Yes i have used the same tutorial.But when i execute the "psql -d
>> yourdatabase -f postgis.sql" command. i get :
>> spheroid does not exist.
>> geometry does not exist.
>> and many others.....
>> Furthermore if i try "psql -d yourdatabase -f spatial_ref_sys.sql" this
>> command i get:
>> spatial_ref_sys.sql table does not exist.
>> Note: I am using "postgis-2.0.0alpha3SVN". The .sql files are not created
>> at
>> the locations specified by this tutorial.
>> 1) my postgis.sql is at:   /postgis/postgis.sql
>> 2) my rtpostgis.sql is at: /raster/rt_pg/rtpostgis.sql
>> similarly rest of the .sql files are also at other locations.
>> I dont know where am i going wrong. Please mention the details about the
>> dependencies if any.
>> thanks for replying.
>> nikhil morajkar
>> IIT Bombay.
>> View this message in context:
>> http://postgis.17.n6.nabble.com/Installing-raster-in-POSTGIS-2-0-tp4378919p4383502.html
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> ~$ whoami
> Mathieu Basille, Post-Doc
> ~$ locate
> Laboratoire d'Écologie Comportementale et de Conservation de la Faune
> + Centre d'Étude de la Forêt
> Département de Biologie
> Université Laval, Québec
> ~$ info
> http://ase-research.org/basille
> ~$ fortune
> ``If you can't win by reason, go for volume.''
> Calvin, by Bill Watterson.
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
