[postgis-users] Installing raster in POSTGIS 2.0
Bborie Park
bkpark at ucdavis.edu
Fri Feb 10 07:10:09 PST 2012
Gah. Stupid me for clicking the wrong button. Let me return to where I was...
Specifically, we need to see what are the other errors when you
attempt to load postgis.sql. If postgis.sql is not loaded,
spatial_ref_sys.sql and rtpostgis.sql will NOT load. Have you checked
your PostgreSQL logs to see if there are any error messages when
starting to load postgis.sql?
-bborie
On Fri, Feb 10, 2012 at 7:07 AM, Bborie Park <bkpark at ucdavis.edu> wrote:
> You'll need to provide significantly more information about the errors
> than you're currently providing.
> The messages similar to "spheroid does not exist" are probably NOTICEs
> and are expected due to the chicken-egg problem relating to TYPEs.
> On Fri, Feb 10, 2012 at 6:57 AM, Mathieu Basille
> <basille at ase-research.org> wrote:
>> Are these ERROR messages or simple NOTICE? It might be working despite the
>> messages... Sorry I can't help more. I used it a couple of months ago
>> without any problems, but I guess things changed since then (as I understand
>> from the modification of file locations).
>> It seems more a problem of PostGIS developers than users now. Please keep
>> the list informed about your progress, as it would be very valuable
>> information for people using Debian-based distributions.
>> Best of luck,
>> Mathieu.
>> Le 10/02/2012 09:45, nikhil a écrit :
>>> Hi,
>>> Yes i have used the same tutorial.But when i execute the "psql -d
>>> yourdatabase -f postgis.sql" command. i get :
>>> spheroid does not exist.
>>> geometry does not exist.
>>> and many others.....
>>> Furthermore if i try "psql -d yourdatabase -f spatial_ref_sys.sql" this
>>> command i get:
>>> spatial_ref_sys.sql table does not exist.
>>> Note: I am using "postgis-2.0.0alpha3SVN". The .sql files are not created
>>> at
>>> the locations specified by this tutorial.
>>> 1) my postgis.sql is at: /postgis/postgis.sql
>>> 2) my rtpostgis.sql is at: /raster/rt_pg/rtpostgis.sql
>>> similarly rest of the .sql files are also at other locations.
>>> I dont know where am i going wrong. Please mention the details about the
>>> dependencies if any.
>>> thanks for replying.
>>> nikhil morajkar
>>> IIT Bombay.
>>> View this message in context:
>>> http://postgis.17.n6.nabble.com/Installing-raster-in-POSTGIS-2-0-tp4378919p4383502.html
>>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> ~$ whoami
>> Mathieu Basille, Post-Doc
>> ~$ locate
>> Laboratoire d'Écologie Comportementale et de Conservation de la Faune
>> + Centre d'Étude de la Forêt
>> Département de Biologie
>> Université Laval, Québec
>> ~$ info
>> http://ase-research.org/basille
>> ~$ fortune
>> ``If you can't win by reason, go for volume.''
>> Calvin, by Bill Watterson.
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
Bborie Park
Programmer
UC Davis
530-752-8380
