[postgis-users] hard upgrade
Sandro Santilli
strk at keybit.net
Fri Feb 10 09:10:04 PST 2012
On Fri, Feb 10, 2012 at 06:07:10PM +0100, Sandro Santilli wrote:
> On Fri, Feb 10, 2012 at 11:43:34AM -0500, Stephen Crawford wrote:
> > Brave or stupid, not yet sure which one. The log file is big, so I
> > put it here if you can take a look:
> If you pass a -v switch to postgis_restore.pl it'll give you
> more debugging output on STDERR. That'd be intersting too.
Actually, are you sure you carefully followed the intructions ?
You were supposed to create and spatially-enable the new database
prior to restoring the dump into it.
I'm assuming you're upgrading to 2.0, right ?
Here are the full instructions:
http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html#hard_upgrade
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net
`-o------'
