[postgis-users] hard upgrade
Stephen Crawford
src176 at psu.edu
Fri Feb 10 09:37:21 PST 2012
Actually I'm upgrading to 1.4 from 1.2. This is for our legacy
databases. I'll eventually be going to 2.0 for our newer stuff. So
I've been following the instructions from the 1.4 docs. But I'll try it
next into a new database.
On 2/10/2012 12:10 PM, Sandro Santilli wrote:
> On Fri, Feb 10, 2012 at 06:07:10PM +0100, Sandro Santilli wrote:
>> On Fri, Feb 10, 2012 at 11:43:34AM -0500, Stephen Crawford wrote:
>>> Brave or stupid, not yet sure which one. The log file is big, so I
>>> put it here if you can take a look:
>> If you pass a -v switch to postgis_restore.pl it'll give you
>> more debugging output on STDERR. That'd be intersting too.
> Actually, are you sure you carefully followed the intructions ?
> You were supposed to create and spatially-enable the new database
> prior to restoring the dump into it.
> I'm assuming you're upgrading to 2.0, right ?
> Here are the full instructions:
> http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html#hard_upgrade
> --strk;
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.0 !
> | / 2.0 | http://strk.keybit.net
> `-o------'
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
src176 at psu.edu
814.865.9905
