[postgis-users] Installing raster in POSTGIS 2.0
Sandro Santilli strk at keybit.net
Mon Feb 13 00:35:31 PST 2012
On Fri, Feb 10, 2012 at 12:24:11PM -0800, nikhil wrote:
> INSTALLATION PROBLEMS:
> I have tried installing from
> (http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html)
> this again and this time i skipped;
> 2.5. Create a spatially-enabled database on PostgreSQL lower than 9.1
> and directly did the next step, I could successfully run this command:
> psql -d [yourdatabase] -c "CREATE EXTENSION postgis;"
> But the following command dint run successfully:
> psql -d [yourdatabase] -c "CREATE EXTENSION postgis_topology;"  and gave
> following error:
> ERROR:  function getringedges(character varying, integer) does not exist
Sounds like a bug. Could you please file a ticket _after_ trying
latest alpha ?
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net
  `-o------'
