[postgis-users] [?? Probable Spam] Re: Trouble seeinglisting tables
Francisco Salas Rosette fsalas at pinar.geocuba.cu
Mon Feb 13 14:08:47 PST 2012
Bob, this is one example for connection in mapserver with postgis , in DATA
section do you put the selection.
on the other hand, do you review in the geometry_columns table in public
scheme , if there exists you table?
the  geometry_columns table , describe projection, geometric columns , etc.
  LAYER
    CONNECTION "dbname=datosfg user=postgres password=postgres
host=localhost"
    CONNECTIONTYPE POSTGIS
    DATA "wkb_geometry from suelo USING SRID=4267001 USING Unique gid"
    METADATA
      "srid"              "4267001"
      "table_name"            " suelo"
      "cant_class_temat" "0"
      "field_list"    "gid, rugosidad, humedad, profundidad, suelo"
    END
    NAME "Suelos"
    STATUS ON
    TEMPLATE "ttt"
    TYPE POLYGON
    UNITS METERS
    CLASS
      NAME "Suelos"
      STYLE
        ANGLE 360
        COLOR 174 183 180
        OPACITY 100
        OUTLINECOLOR 35 80 65
        SYMBOL 0
      END
    END
  END
Francisco Salas
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] En nombre de
Bistrais, Bob
Enviado el: lunes, 13 de febrero de 2012 04:47 p.m.
Para: PostGIS Users Discussion
Asunto: [?? Probable Spam] Re: [postgis-users] Trouble seeinglisting tables
Hello Francisco,
I loaded the data using the PostGIS Shapefile and DBF Loader.  The table has
a column called the_geom.  I don't see any column for the SRS or projection.
I made some progress- I forgot to put quotes on my table name, so my select
command should be:
SELECT * from "mytable";
-and that works correctly.
But, I am still not able to see my layer in MapServer.  I have posted to the
MapServer list as well, to see if anyone can help.  I get a MapServer error
that says:
ERROR: relation "mytable" does not exist.
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Sent: Monday, February 13, 2012 4:44 PM
To: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] [!! SPAM] Trouble seeinglisting tables
Bob, do you review if there exists mytable in the geometry_columns table?
How do you loaded this table?
Francisco salas
Bistrais, Bob
Enviado el: lunes, 13 de febrero de 2012 03:58 p.m.
Asunto: [!! SPAM] [postgis-users] Trouble seeinglisting tables
I am having trouble on a pretty basic level.  I loaded a couple shapefiles
into PostGIS.  I can see that they successfully loaded when I use pgAdmin.
But when I go to command line, I have trouble.  I can do a \d command and
see the tables exist in the database.  But if I do a select * from mytable;
I get an errer, "relation "mytable" does not exist.  What am I doing wrong
here?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120213/4f0ee116/attachment.html>
