[postgis-users] [!! SPAM] Trouble seeinglisting tables
Bistrais, Bob
Bob.Bistrais at maine.gov
Mon Feb 13 13:47:25 PST 2012
Hello Francisco,
I loaded the data using the PostGIS Shapefile and DBF Loader. The table
has a column called the_geom. I don't see any column for the SRS or
projection.
I made some progress- I forgot to put quotes on my table name, so my
select command should be:
SELECT * from "mytable";
-and that works correctly.
But, I am still not able to see my layer in MapServer. I have posted to
the MapServer list as well, to see if anyone can help. I get a
MapServer error that says:
ERROR: relation "mytable" does not exist...
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Francisco Salas Rosette
Sent: Monday, February 13, 2012 4:44 PM
To: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] [!! SPAM] Trouble seeinglisting tables
Bob, do you review if there exists mytable in the geometry_columns
table?
How do you loaded this table?
Francisco salas
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] En nombre de
Bistrais, Bob
Enviado el: lunes, 13 de febrero de 2012 03:58 p.m.
Para: PostGIS Users Discussion
Asunto: [!! SPAM] [postgis-users] Trouble seeinglisting tables
I am having trouble on a pretty basic level. I loaded a couple
shapefiles into PostGIS. I can see that they successfully loaded when I
use pgAdmin. But when I go to command line, I have trouble. I can do a
\d command and see the tables exist in the database. But if I do a
select * from mytable; I get an errer, "relation "mytable" does not
exist. What am I doing wrong here?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120213/1a93241b/attachment.html>
