[postgis-users] Raster and shapefile in POSTGIS
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Tue Feb 14 06:07:51 PST 2012
Could you be more explicit on how it did not work? What message did you get after you did raster2pgsql?
Thanks,
Pierre
> The following command which were given in postgis link
> (http://www.postgis.org/documentation/manual-
> svn/using_raster.xml.html#RT_Loading_Rasters
> ) did not worked
> raster2pgsql -G --- did not work
> raster2pgsql -s 4236 -I -C -M *.tif -F -t 100x100 public.demelevation | psql -d
> gisdb --- did not work
> I executed above commands from commandline as wall as POSTGIS
> *also provide me the link which provide detailed(step by step) information about
> raster and shapefile import in POSTGIS 2.0*
