[postgis-users] [PostGIS] Make error in building PostGIS 2.0
GeoFox
Edison.Tam at ngc.com
Wed Feb 15 07:15:09 PST 2012
I did configure with the -w flag as stated in the instruction; json
configure, make, and make install ran fine. However, the same error message
error when I try to make PostGIS.
Do you need to copy everything in json-rel to the postresql install folder?
from /c/projects/json/rel-9.0 to /c/projects/pg/pg91/
the instruction does not say this step, but I did it.
Edison Tam
NGC SWE
US
View this message in context: http://postgis.17.n6.nabble.com/PostGIS-Make-error-in-building-PostGIS-2-0-tp4470575p4472505.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
