[postgis-users] PostGIS Manager QGIS Plugin error
    Ben Madin
    lists at remoteinformation.com.au
    Wed Feb 15 23:24:49 PST 2012
Kevin,
That sounds like a syntax error in the plugin itself. You probably need to contact the maintainer. I can't actually get it to work in QGIS 1.7.3 on OSX 10.6.8
cheers
Ben
On 16/02/2012, at 7:21 AM, Kevin Goulding wrote:
> I'm just now getting set up with a PostGIS database connected with QGIS.  A few plugins are giving me errors when I try to connect to my database. I am using Mac OS X 10.6.8 and QGIS 1.8.
> When I try to connect to my PostGIS database using the "PostGIS Manager" plugin, I receive the following error:
> “Couldn’t connect to database: missing “=” after “‘” in connection info string”.
> Any thoughts?  I will add that I have successfully added PostGIS layers to my project, but now want to start using pgRouting, so need to connect to the database.  I receive the exact same error when attempting to use the "pgRouting Layer" plugin.
> Thanks! Kevin
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120216/59078705/attachment.html>
