[postgis-users] Bogus unknown geometry error from ST_Transform
Aren Cambre
aren at arencambre.com
Sun Feb 19 07:13:01 PST 2012
Nope. BTW, there is an extraneous parenthesis in your example. Here's what
I used:
*UPDATE gis."gz_2010_48_160_00_500k"*
*SET "the_geom_3081" = ST_Transform(ST_Setsrid(the_geom, 4629),3081);*
(BTW, I said 4326 earlier, but I should have been using 4269. Not sure that
explains the errors, however.)
Now I get this:
*ERROR: new row for relation "gz_2010_48_160_00_500k" violates check
constraint "enforce_geotype_the_geom_3081"*
This is just bizarre because the source and destination column are POLYGON
types.
Here's what I get when running *ST_AsEWKT(the_geom)*:
*"POLYGON((-94.940569 29.330815,-94.93334 29.329038,-94.930971
29.327708,-94.929679 29.32634,-94.938834 29.320412,-94.946644
29.323065,-94.946988 29.326066,-94.94085 29.330469,-94.940569 29.330815))"*
I just double-checked, and there are no other rows in
public.geometry_columns describing anything in the
*gz_2010_48_160_00_500k*table besides the two rows I pasted earlier.
Here's that constraint:
*enforce_geotype_the_geom_3081 CHECK (geometrytype(the_geom_3081) =
'POLYGON'::text OR the_geom_3081 IS NULL);*
Aren
On Sun, Feb 19, 2012 at 2:10 AM, <pcreso at pcreso.com> wrote:
> Does this work?
> *SET "the_geom_3081" = ST_Transform((ST_Setsrid(the_geom, 4326),3081);*
> ie:: is the problem finding the srid from geometry_columns or finding it
> but ST_Transform() fails even when given the srid?
> Even if there is a bug, this may work for you until fixed?
> Brent Wood
> --- On *Sun, 2/19/12, René Romero Benavides <ichbinrene at gmail.com>* wrote:
> From: René Romero Benavides <ichbinrene at gmail.com>
> Subject: Re: [postgis-users] Bogus unknown geometry error from ST_Transform
> To: postgis-users at postgis.refractions.net
> Date: Sunday, February 19, 2012, 8:37 PM
> El 18/02/2012 11:29 p.m., Aren Cambre escribió:
> ST_Transform is returning a bogus error of* Input geometry has unknown
> (-1) SRID*.
> Here's the query:
> *SET "the_geom_3081" = ST_Transform(the_geom, 3081);*
> I said "bogus" because the database's *public.geometry_columns* table
> has valid values for these two columns, and neither has SRID of -1:
> *34281;"''";"gis";"gz_2010_48_160_00_500k";"the_geom";2;4326;"POLYGON"*
> 34276;"''";"gis";"gz_2010_48_160_00_500k";"the_geom_3081";2;3081;"POLYGON"
> What gives?
> Aren
> postgis-users mailing listpostgis-users at postgis.refractions.net <http://mc/compose?to=postgis-users@postgis.refractions.net>http://postgis.refractions.net/mailman/listinfo/postgis-users
> I thought a SRID of -1 was a synonym for the default one (4326). But
> don't take my word for it, I'm beginning with postgis.
> http://sharingtechknowledge.blogspot.com/
> -----Inline Attachment Follows-----
> postgis-users at postgis.refractions.net<http://mc/compose?to=postgis-users@postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120219/0b1f7f55/attachment.html>
