[postgis-users] Bogus unknown geometry error from ST_Transform
Aren Cambre aren at arencambre.com
Sun Feb 19 12:29:30 PST 2012
OK, I figured out the second error. The TIGER places dataset for Texas has
both POLYGON and MULTIPOLYGON types, hence violating the *
enforce_geotype_the_geom_3081* constraint.
However, I think the original issue is a bug. If the geometry object has no
SRID specified, as in my case, then ST_Transform should use whatever's
specified in *public.geometry_columns*. I should not be getting errors
about SRID of -1 if something is specified in  *public.geometry_columns*.
Aren
On Sun, Feb 19, 2012 at 9:13 AM, Aren Cambre <aren at arencambre.com> wrote:
> Nope. BTW, there is an extraneous parenthesis in your example. Here's what
> I used:
> *UPDATE gis."gz_2010_48_160_00_500k"*
> *SET "the_geom_3081" = ST_Transform(ST_Setsrid(the_geom, 4629),3081);*
> (BTW, I said 4326 earlier, but I should have been using 4269. Not sure
> that explains the errors, however.)
> Now I get this:
> *ERROR: new row for relation "gz_2010_48_160_00_500k" violates check
> constraint "enforce_geotype_the_geom_3081"*
> This is just bizarre because the source and destination column are POLYGON
> types.
> Here's what I get when running *ST_AsEWKT(the_geom)*:
> *"POLYGON((-94.940569 29.330815,-94.93334 29.329038,-94.930971
> 29.327708,-94.929679 29.32634,-94.938834 29.320412,-94.946644
> 29.323065,-94.946988 29.326066,-94.94085 29.330469,-94.940569 29.330815))"
> I just double-checked, and there are no other rows in
> public.geometry_columns describing anything in the *gz_2010_48_160_00_500k
> * table besides the two rows I pasted earlier.
> Here's that constraint:
> *enforce_geotype_the_geom_3081 CHECK (geometrytype(the_geom_3081) =
> 'POLYGON'::text OR the_geom_3081 IS NULL);*
> Aren
> On Sun, Feb 19, 2012 at 2:10 AM, <pcreso at pcreso.com> wrote:
>> Does this work?
>> *SET "the_geom_3081" = ST_Transform((ST_Setsrid(the_geom, 4326),3081);*
>> ie:: is the problem finding the srid from geometry_columns or finding it
>> but ST_Transform() fails even when given the srid?
>> Even if there is a bug, this may work for you until fixed?
>> Brent Wood
>> --- On *Sun, 2/19/12, René Romero Benavides <ichbinrene at gmail.com>*wrote:
>> From: René Romero Benavides <ichbinrene at gmail.com>
>> Subject: Re: [postgis-users] Bogus unknown geometry error from
>> ST_Transform
>> To: postgis-users at postgis.refractions.net
>> Date: Sunday, February 19, 2012, 8:37 PM
>>  El 18/02/2012 11:29 p.m., Aren Cambre escribió:
>> ST_Transform is returning a bogus error of* Input geometry has unknown
>> (-1) SRID*.
>>  Here's the query:
>> *SET "the_geom_3081" = ST_Transform(the_geom, 3081);*
>>  I said "bogus" because the database's *public.geometry_columns* table
>> has valid values for these two columns, and neither has SRID of -1:
>>  *34281;"''";"gis";"gz_2010_48_160_00_500k";"the_geom";2;4326;"POLYGON"*
>> 34276;"''";"gis";"gz_2010_48_160_00_500k";"the_geom_3081";2;3081;"POLYGON"
>>  What gives?
>>  Aren
>> postgis-users mailing listpostgis-users at postgis.refractions.net <http://mc/compose?to=postgis-users@postgis.refractions.net>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>  I thought a SRID of -1 was a synonym for the default one (4326). But
>> don't take my word for it, I'm beginning with postgis.
>>  http://sharingtechknowledge.blogspot.com/
>> -----Inline Attachment Follows-----
>> postgis-users at postgis.refractions.net<http://mc/compose?to=postgis-users@postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120219/a50bc680/attachment.html>
