[postgis-users] Bogus unknown geometry error from ST_Transform
Aren Cambre
aren at arencambre.com
Sun Feb 19 13:00:09 PST 2012
I hear you and am OK with reclassifying as an enhancement. However, what's
the purpose of public.geometry_columns?
If it's just ephemeral, then I accept your "do-what-I-mean-not-what-I-say"
point.
If it's supposed to be accurate metadata, then if some functionality needs
this metadata *and* its missing from the geometry field, why not
consult public.geometry_columns?
Aren
On Sun, Feb 19, 2012 at 2:35 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> A bug is unspecified or unexpected behavior, and I'm afraid your case is
> neither: the system is operating exactly as I would expect. You have
> outlined what might be considered a legitimate enhancement, but it's on the
> edge, because do-what-I-mean-not-what-I-say behavior can cause other people
> problems from time to time.
> P.
> On Sun, Feb 19, 2012 at 12:29 PM, Aren Cambre <aren at arencambre.com> wrote:
>> OK, I figured out the second error. The TIGER places dataset for Texas
>> has both POLYGON and MULTIPOLYGON types, hence violating the *
>> enforce_geotype_the_geom_3081* constraint.
>> However, I think the original issue is a bug. If the geometry object has
>> no SRID specified, as in my case, then ST_Transform should use whatever's
>> specified in *public.geometry_columns*. I should not be getting errors
>> about SRID of -1 if something is specified in *public.geometry_columns*.
>> Aren
>> On Sun, Feb 19, 2012 at 9:13 AM, Aren Cambre <aren at arencambre.com> wrote:
>>> Nope. BTW, there is an extraneous parenthesis in your example. Here's
>>> what I used:
>>> *UPDATE gis."gz_2010_48_160_00_500k"*
>>> *SET "the_geom_3081" = ST_Transform(ST_Setsrid(the_geom, 4629),3081);*
>>> (BTW, I said 4326 earlier, but I should have been using 4269. Not sure
>>> that explains the errors, however.)
>>> Now I get this:
>>> *ERROR: new row for relation "gz_2010_48_160_00_500k" violates check
>>> constraint "enforce_geotype_the_geom_3081"*
>>> This is just bizarre because the source and destination column are
>>> POLYGON types.
>>> Here's what I get when running *ST_AsEWKT(the_geom)*:
>>> *"POLYGON((-94.940569 29.330815,-94.93334 29.329038,-94.930971
>>> 29.327708,-94.929679 29.32634,-94.938834 29.320412,-94.946644
>>> 29.323065,-94.946988 29.326066,-94.94085 29.330469,-94.940569 29.330815))"
>>> I just double-checked, and there are no other rows in
>>> public.geometry_columns describing anything in the *
>>> gz_2010_48_160_00_500k* table besides the two rows I pasted earlier.
>>> Here's that constraint:
>>> *enforce_geotype_the_geom_3081 CHECK (geometrytype(the_geom_3081) =
>>> 'POLYGON'::text OR the_geom_3081 IS NULL);*
>>> Aren
>>> On Sun, Feb 19, 2012 at 2:10 AM, <pcreso at pcreso.com> wrote:
>>>> Does this work?
>>>> *SET "the_geom_3081" = ST_Transform((ST_Setsrid(the_geom, 4326),3081);*
>>>> ie:: is the problem finding the srid from geometry_columns or finding
>>>> it but ST_Transform() fails even when given the srid?
>>>> Even if there is a bug, this may work for you until fixed?
>>>> Brent Wood
>>>> --- On *Sun, 2/19/12, René Romero Benavides <ichbinrene at gmail.com>*wrote:
>>>> From: René Romero Benavides <ichbinrene at gmail.com>
>>>> Subject: Re: [postgis-users] Bogus unknown geometry error from
>>>> ST_Transform
>>>> To: postgis-users at postgis.refractions.net
>>>> Date: Sunday, February 19, 2012, 8:37 PM
>>>> El 18/02/2012 11:29 p.m., Aren Cambre escribió:
>>>> ST_Transform is returning a bogus error of* Input geometry has unknown
>>>> (-1) SRID*.
>>>> Here's the query:
>>>> *SET "the_geom_3081" = ST_Transform(the_geom, 3081);*
>>>> I said "bogus" because the database's *public.geometry_columns* table
>>>> has valid values for these two columns, and neither has SRID of -1:
>>>> *34281;"''";"gis";"gz_2010_48_160_00_500k";"the_geom";2;4326;"POLYGON"
>>>> 34276;"''";"gis";"gz_2010_48_160_00_500k";"the_geom_3081";2;3081;"POLYGON"
>>>> What gives?
>>>> Aren
>>>> _______________________________________________
>>>> postgis-users mailing listpostgis-users at postgis.refractions.net <http://mc/compose?to=postgis-users@postgis.refractions.net>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> I thought a SRID of -1 was a synonym for the default one (4326). But
>>>> don't take my word for it, I'm beginning with postgis.
>>>> http://sharingtechknowledge.blogspot.com/
>>>> -----Inline Attachment Follows-----
>>>> postgis-users at postgis.refractions.net<http://mc/compose?to=postgis-users@postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120219/1e2dc644/attachment.html>
