[postgis-users] Bogus unknown geometry error from ST_Transform
Paul Ramsey
pramsey at opengeo.org
Sun Feb 19 13:19:16 PST 2012
As of 2.0 the whole question will be moot, as geometry_columns will be a
view and will accurately reflect the state of the tables... so a table with
no known srid will show up with unknown srid, and a table with known srid
will have an entry... but since it will not be possible to insert an
unknown srid geometry into a known srid table, your case won't ever arise.
P.
On Sun, Feb 19, 2012 at 1:00 PM, Aren Cambre <aren at arencambre.com> wrote:
> I hear you and am OK with reclassifying as an enhancement. However, what's
> the purpose of public.geometry_columns?
> If it's just ephemeral, then I accept your "do-what-I-mean-not-what-I-say"
> point.
> If it's supposed to be accurate metadata, then if some functionality needs
> this metadata *and* its missing from the geometry field, why not
> consult public.geometry_columns?
> Aren
> On Sun, Feb 19, 2012 at 2:35 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
>> A bug is unspecified or unexpected behavior, and I'm afraid your case is
>> neither: the system is operating exactly as I would expect. You have
>> outlined what might be considered a legitimate enhancement, but it's on the
>> edge, because do-what-I-mean-not-what-I-say behavior can cause other people
>> problems from time to time.
>> P.
>> On Sun, Feb 19, 2012 at 12:29 PM, Aren Cambre <aren at arencambre.com>wrote:
>>> OK, I figured out the second error. The TIGER places dataset for Texas
>>> has both POLYGON and MULTIPOLYGON types, hence violating the *
>>> enforce_geotype_the_geom_3081* constraint.
>>> However, I think the original issue is a bug. If the geometry object has
>>> no SRID specified, as in my case, then ST_Transform should use whatever's
>>> specified in *public.geometry_columns*. I should not be getting errors
>>> about SRID of -1 if something is specified in *public.geometry_columns*
>>> Aren
>>> On Sun, Feb 19, 2012 at 9:13 AM, Aren Cambre <aren at arencambre.com>wrote:
>>>> Nope. BTW, there is an extraneous parenthesis in your example. Here's
>>>> what I used:
>>>> *UPDATE gis."gz_2010_48_160_00_500k"*
>>>> *SET "the_geom_3081" = ST_Transform(ST_Setsrid(the_geom, 4629),3081);*
>>>> (BTW, I said 4326 earlier, but I should have been using 4269. Not sure
>>>> that explains the errors, however.)
>>>> Now I get this:
>>>> *ERROR: new row for relation "gz_2010_48_160_00_500k" violates check
>>>> constraint "enforce_geotype_the_geom_3081"*
>>>> This is just bizarre because the source and destination column are
>>>> POLYGON types.
>>>> Here's what I get when running *ST_AsEWKT(the_geom)*:
>>>> *"POLYGON((-94.940569 29.330815,-94.93334 29.329038,-94.930971
>>>> 29.327708,-94.929679 29.32634,-94.938834 29.320412,-94.946644
>>>> 29.323065,-94.946988 29.326066,-94.94085 29.330469,-94.940569 29.330815))"
>>>> I just double-checked, and there are no other rows in
>>>> public.geometry_columns describing anything in the *
>>>> gz_2010_48_160_00_500k* table besides the two rows I pasted earlier.
>>>> Here's that constraint:
>>>> *enforce_geotype_the_geom_3081 CHECK (geometrytype(the_geom_3081) =
>>>> 'POLYGON'::text OR the_geom_3081 IS NULL);*
>>>> Aren
>>>> On Sun, Feb 19, 2012 at 2:10 AM, <pcreso at pcreso.com> wrote:
>>>>> Does this work?
>>>>> *SET "the_geom_3081" = ST_Transform((ST_Setsrid(the_geom, 4326),3081);
>>>>> ie:: is the problem finding the srid from geometry_columns or finding
>>>>> it but ST_Transform() fails even when given the srid?
>>>>> Even if there is a bug, this may work for you until fixed?
>>>>> Brent Wood
>>>>> --- On *Sun, 2/19/12, René Romero Benavides <ichbinrene at gmail.com>*wrote:
>>>>> From: René Romero Benavides <ichbinrene at gmail.com>
>>>>> Subject: Re: [postgis-users] Bogus unknown geometry error from
>>>>> ST_Transform
>>>>> To: postgis-users at postgis.refractions.net
>>>>> Date: Sunday, February 19, 2012, 8:37 PM
>>>>> El 18/02/2012 11:29 p.m., Aren Cambre escribió:
>>>>> ST_Transform is returning a bogus error of* Input geometry has
>>>>> unknown (-1) SRID*.
>>>>> Here's the query:
>>>>> *SET "the_geom_3081" = ST_Transform(the_geom, 3081);*
>>>>> I said "bogus" because the database's *public.geometry_columns*table has valid values for these two columns, and neither has SRID of -1:
>>>>> 34281;"''";"gis";"gz_2010_48_160_00_500k";"the_geom";2;4326;"POLYGON"*
>>>>> 34276;"''";"gis";"gz_2010_48_160_00_500k";"the_geom_3081";2;3081;"POLYGON"
>>>>> What gives?
>>>>> Aren
>>>>> _______________________________________________
>>>>> postgis-users mailing listpostgis-users at postgis.refractions.net <http://mc/compose?to=postgis-users@postgis.refractions.net>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>> I thought a SRID of -1 was a synonym for the default one (4326). But
>>>>> don't take my word for it, I'm beginning with postgis.
>>>>> http://sharingtechknowledge.blogspot.com/
>>>>> -----Inline Attachment Follows-----
>>>>> postgis-users at postgis.refractions.net<http://mc/compose?to=postgis-users@postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120219/ca28b719/attachment.html>
