[postgis-users] Calling pgsql2shp.exe via python
Horst Düster horst.duester at kappasys.ch
Mon Feb 20 15:13:10 PST 2012
Be careful with the double quotes
Dr. Horst Düster
Kappasys
Alte Bernstrasse 13
CH-4500 Solothurn
Tel.: +41 (0) 32 514 00 40
Mobil: +41 (0) 76 408 51 06
eMail: horst.duester at kappasys.ch
skype: horstduester
Twitter: moazagotl
Web: www.kappasys.ch
lat: N 47° 12' 06.408" lon: E 7° 32' 13.740"
Am 21.02.2012 00:11, schrieb David Quinn:
> Stefan
> Yes - It's just one line in my python file and I double-checked my quotes.
> -David
> On Mon, Feb 20, 2012 at 6:04 PM, Stefan Keller<sfkeller at gmail.com>  wrote:
>> David
>> Just to be sure: You did make one single line without line breaks from the
>> mail?
>> os.system('start "C:\Program Files
>> (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe" -f D:\testShapefile.shp -h
>> localhost -u postgres -p 5432 test_db "SELECT * FROM
>> myschema.testquery"')
>> -Stefan
>> 2012/2/20 David Quinn<daithiquinn at gmail.com>:
>>> I did try that and got the following error message:
>>> "Windows cannot find '-f'. Make sure that you typed the name correctly,
>> and
>>> then try again."
>>> On Mon, Feb 20, 2012 at 5:49 PM, Paul Ramsey<pramsey at opengeo.org>
>> wrote:
>>>> Your quotes are misplaced, try
>>>> -f
>>>> D:\testShapefile.shp -h localhost -u postgres -p 5432 test_db "SELECT *
>>>> FROM
>>>> On Mon, Feb 20, 2012 at 2:24 PM, David Quinn<daithiquinn at gmail.com>
>>>> wrote:
>>>>> I'm trying to call the pgsql2shp.exe function using python, as I would
>>>>> like
>>>>> to be able to loop through some tables. What I've tried doing is the
>>>>> following:
>>>>> import os
>>>>> (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe -f
>>>>> FROM
>>>>> myschema.testquery""')
>>>>> When I paste the line:
>>>>> C:\Program Files (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe -f
>>>>> FROM
>>>>> myschema.testquery"
>>>>> it produces a shapefile without a problem. However, my python script
>>>>> flashes
>>>>> open a CMD terminal, but it disappears before I see what is happening
>>>>> and
>>>>> does not produce any output. I'm using PostGIS 2.0, Windows 7, and
>>>>> Python
>>>>> 2.6.5.
>>>>> If there is an alternative approach to python for this, I will happily
>>>>> try
>>>>> it out.
>>>>> (I hope this question is not too off-topic!)
>>>>> Thanks,
>>>>> David
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
