[postgis-users] Calling pgsql2shp.exe via python
David Quinn daithiquinn at gmail.com
Mon Feb 20 15:11:42 PST 2012
Stefan
Yes - It's just one line in my python file and I double-checked my quotes.
-David
On Mon, Feb 20, 2012 at 6:04 PM, Stefan Keller <sfkeller at gmail.com> wrote:
> David
> Just to be sure: You did make one single line without line breaks from the
> mail?
> os.system('start "C:\Program Files
> (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe" -f D:\testShapefile.shp -h
> localhost -u postgres -p 5432 test_db "SELECT * FROM
> myschema.testquery"')
> -Stefan
> 2012/2/20 David Quinn <daithiquinn at gmail.com>:
> > I did try that and got the following error message:
> > "Windows cannot find '-f'. Make sure that you typed the name correctly,
> and
> > then try again."
> > On Mon, Feb 20, 2012 at 5:49 PM, Paul Ramsey <pramsey at opengeo.org>
> wrote:
> >> Your quotes are misplaced, try
> >> -f
> >> D:\testShapefile.shp -h localhost -u postgres -p 5432 test_db "SELECT *
> >> FROM
> >> On Mon, Feb 20, 2012 at 2:24 PM, David Quinn <daithiquinn at gmail.com>
> >> wrote:
> >> > I'm trying to call the pgsql2shp.exe function using python, as I would
> >> > like
> >> > to be able to loop through some tables. What I've tried doing is the
> >> > following:
> >> > import os
> >> > (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe -f
> >> > FROM
> >> > myschema.testquery""')
> >> > When I paste the line:
> >> > C:\Program Files (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe -f
> >> > FROM
> >> > myschema.testquery"
> >> > it produces a shapefile without a problem. However, my python script
> >> > flashes
> >> > open a CMD terminal, but it disappears before I see what is happening
> >> > and
> >> > does not produce any output. I'm using PostGIS 2.0, Windows 7, and
> >> > Python
> >> > 2.6.5.
> >> > If there is an alternative approach to python for this, I will happily
> >> > try
> >> > it out.
> >> > (I hope this question is not too off-topic!)
> >> > Thanks,
> >> > David
> >> > _______________________________________________
> >> > postgis-users mailing list
> >> > postgis-users at postgis.refractions.net
> >> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120220/5f17e438/attachment.html>
