[postgis-users] Calling pgsql2shp.exe via python
Stefan Keller sfkeller at gmail.com
Mon Feb 20 15:04:45 PST 2012
David
Just to be sure: You did make one single line without line breaks from the mail?
os.system('start "C:\Program Files
(x86)\PostgreSQL\9.1\bin\pgsql2shp.exe" -f D:\testShapefile.shp -h
localhost -u postgres -p 5432 test_db "SELECT * FROM
myschema.testquery"')
-Stefan
2012/2/20 David Quinn <daithiquinn at gmail.com>:
> I did try that and got the following error message:
> "Windows cannot find '-f'. Make sure that you typed the name correctly, and
> then try again."
> On Mon, Feb 20, 2012 at 5:49 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
>> Your quotes are misplaced, try
>> os.system('start "C:\Program Files (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe"
>> -f
>> D:\testShapefile.shp -h localhost -u postgres -p 5432 test_db "SELECT *
>> FROM
>> On Mon, Feb 20, 2012 at 2:24 PM, David Quinn <daithiquinn at gmail.com>
>> wrote:
>> > I'm trying to call the pgsql2shp.exe function using python, as I would
>> > like
>> > to be able to loop through some tables. What I've tried doing is the
>> > following:
>> > import os
>> > (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe -f
>> > FROM
>> > myschema.testquery""')
>> > When I paste the line:
>> > C:\Program Files (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe -f
>> > FROM
>> > myschema.testquery"
>> > it produces a shapefile without a problem. However, my python script
>> > flashes
>> > open a CMD terminal, but it disappears before I see what is happening
>> > and
>> > does not produce any output. I'm using PostGIS 2.0, Windows 7, and
>> > Python
>> > 2.6.5.
>> > If there is an alternative approach to python for this, I will happily
>> > try
>> > it out.
>> > (I hope this question is not too off-topic!)
>> > Thanks,
>> > David
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
