[postgis-users] Calling pgsql2shp.exe via python
David Quinn daithiquinn at gmail.com
Mon Feb 20 14:54:03 PST 2012
I did try that and got the following error message:
"Windows cannot find '-f'. Make sure that you typed the name correctly, and
then try again."
On Mon, Feb 20, 2012 at 5:49 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Your quotes are misplaced, try
> os.system('start "C:\Program Files (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe"
> -f
> D:\testShapefile.shp -h localhost -u postgres -p 5432 test_db "SELECT *
> FROM
> myschema.testquery"')
> On Mon, Feb 20, 2012 at 2:24 PM, David Quinn <daithiquinn at gmail.com>
> wrote:
> > I'm trying to call the pgsql2shp.exe function using python, as I would
> like
> > to be able to loop through some tables. What I've tried doing is the
> > following:
> > import os
> (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe -f
> FROM
> > myschema.testquery""')
> > When I paste the line:
> > C:\Program Files (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe -f
> FROM
> > myschema.testquery"
> > it produces a shapefile without a problem. However, my python script
> flashes
> > open a CMD terminal, but it disappears before I see what is happening and
> > does not produce any output. I'm using PostGIS 2.0, Windows 7, and Python
> > 2.6.5.
> > If there is an alternative approach to python for this, I will happily
> try
> > it out.
> > (I hope this question is not too off-topic!)
> > Thanks,
> > David
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120220/cc9e8637/attachment.html>
