[postgis-users] Calling pgsql2shp.exe via python
Paul Ramsey
pramsey at opengeo.org
Mon Feb 20 14:49:49 PST 2012
Your quotes are misplaced, try
os.system('start "C:\Program Files (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe" -f
D:\testShapefile.shp -h localhost -u postgres -p 5432 test_db "SELECT * FROM
myschema.testquery"')
On Mon, Feb 20, 2012 at 2:24 PM, David Quinn <daithiquinn at gmail.com> wrote:
> I'm trying to call the pgsql2shp.exe function using python, as I would like
> to be able to loop through some tables. What I've tried doing is the
> following:
> import os
> os.system('start "C:\Program Files (x86)\PostgreSQL\9.1\bin\pgsql2shp.exe -f
> myschema.testquery""')
> When I paste the line:
> myschema.testquery"
> it produces a shapefile without a problem. However, my python script flashes
> open a CMD terminal, but it disappears before I see what is happening and
> does not produce any output. I'm using PostGIS 2.0, Windows 7, and Python
> 2.6.5.
> If there is an alternative approach to python for this, I will happily try
> it out.
> (I hope this question is not too off-topic!)
> Thanks,
> David
> postgis-users mailing list
