[postgis-users] extra function?
Stephen Crawford
src176 at psu.edu
Wed Feb 22 12:16:38 PST 2012
Tried running it and get this:
"ERROR: function _st_summarystats(raster, integer, boolean, integer) is
not unique
LINE 3: AS $$ SELECT _st_summarystats($1, 1::int, $2, 1) $$
HINT: Could not choose best candidate function. You might need to add
explicit type casts"
-Steve
On 2/22/2012 1:59 PM, Bborie Park wrote:
> Interesting. Can you run the following and try again?
> CREATE OR REPLACE FUNCTION st_summarystats(rast raster,
> exclude_nodata_value boolean)
> RETURNS summarystats
> LANGUAGE 'SQL' IMMUTABLE STRICT;
> If that removes the HINT, I'll make the appropriate changes to the code.
> -bborie
> On 02/22/2012 10:48 AM, Stephen Crawford wrote:
>> I only tried the casting because of the messages I get, on of which is:
>> "function _st_summarystats($1, 1, $2, 1) is not unique"
>> and
>> "HINT: Could not choose best candidate function. You might need to add
>> Thanks,
>> steve
>> On 2/22/2012 1:41 PM, Bborie Park wrote:
>>> Hey Steve,
>>> _st_summarystats is an underlying function that isn't meant for use by
>>> end-users. ST_SummaryStats is what you should be using.
>>> The example query you provided shouldn't have any issues and shouldn't
>>> be creating any of those messages. In your situation, you don't even
>>> need the true::boolean.
>>> -bborie
>>> On 02/22/2012 10:34 AM, Stephen Crawford wrote:
>>>> Should I have both _st_summarystats and st_summarystats in my
>>>> database?
>>>> I get messages like "function not unique" and "could not choose best
>>>> candidate function" when doing this:
>>>> SELECT rid, observation_date, ST_SummaryStats(rast::raster,
>>>> true::boolean) FROM spring_ms WHERE observation_date = '2012-02-20';
>>>> I expected to get 187 records (one for each tile).
>>>> Thanks,
>>>> Steve
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
src176 at psu.edu
814.865.9905
