[postgis-users] extra function?
Bborie Park bkpark at ucdavis.edu
Wed Feb 22 13:28:18 PST 2012
Steve,
I know enough to do my own testing and make the necessary changes.
Until I have the time to do so, the following should work.
CREATE OR REPLACE FUNCTION st_summarystats(rast raster,
exclude_nodata_value boolean)
RETURNS summarystats
AS $$ SELECT _st_summarystats($1, 1, $2, 1.) $$
LANGUAGE 'SQL' IMMUTABLE STRICT;
-bborie
On 02/22/2012 12:16 PM, Stephen Crawford wrote:
> Tried running it and get this:
> "ERROR: function _st_summarystats(raster, integer, boolean, integer) is
> not unique
> LINE 3: AS $$ SELECT _st_summarystats($1, 1::int, $2, 1) $$
> HINT: Could not choose best candidate function. You might need to add
> explicit type casts"
> -Steve
> On 2/22/2012 1:59 PM, Bborie Park wrote:
>> Interesting. Can you run the following and try again?
>> If that removes the HINT, I'll make the appropriate changes to the code.
>> -bborie
>> On 02/22/2012 10:48 AM, Stephen Crawford wrote:
>>> I only tried the casting because of the messages I get, on of which is:
>>> "function _st_summarystats($1, 1, $2, 1) is not unique"
>>> and
>>> "HINT: Could not choose best candidate function. You might need to add
>>> Thanks,
>>> steve
>>> On 2/22/2012 1:41 PM, Bborie Park wrote:
>>>> Hey Steve,
>>>> _st_summarystats is an underlying function that isn't meant for use by
>>>> end-users. ST_SummaryStats is what you should be using.
>>>> The example query you provided shouldn't have any issues and shouldn't
>>>> be creating any of those messages. In your situation, you don't even
>>>> need the true::boolean.
>>>> -bborie
>>>> On 02/22/2012 10:34 AM, Stephen Crawford wrote:
>>>>> Should I have both _st_summarystats and st_summarystats in my
>>>>> database?
>>>>> I get messages like "function not unique" and "could not choose best
>>>>> candidate function" when doing this:
>>>>> SELECT rid, observation_date, ST_SummaryStats(rast::raster,
>>>>> true::boolean) FROM spring_ms WHERE observation_date = '2012-02-20';
>>>>> I expected to get 187 records (one for each tile).
>>>>> Thanks,
>>>>> Steve
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
