[postgis-users] extra function?
    John Callahan
    john.callahan at udel.edu
    Wed Feb 22 13:39:25 PST 2012
Steve,
I had a similar issue.  If you look at your list of functions (say through
pgAdmin), you'll probably see multiple instances of that function.  If the
same function is listed more than once, with the same number and type of
arguments, then it will (I think?) report as not unique.  In that case, I
manually deleted the duplicate functions, and then added them back.  To add
them back, look inside the rt_postgis.sql (or postgis.sql) file than comes
with the distribution (I'm using alpha5).  you'll see all of the functions
in there.  Just cut and paste the necessary CREATE OR REPLACE statements
for your functions into the Query Tool or psql console window.
- John
John Callahan, Research Scientist
Delaware Geological Survey, University of Delaware
URL: http://www.dgs.udel.edu
On Wed, Feb 22, 2012 at 4:28 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
> Steve,
> I know enough to do my own testing and make the necessary changes. Until I
> have the time to do so, the following should work.
> CREATE OR REPLACE FUNCTION st_summarystats(rast raster,
> exclude_nodata_value boolean)
> RETURNS summarystats
> AS $$ SELECT _st_summarystats($1, 1, $2, 1.) $$
> LANGUAGE 'SQL' IMMUTABLE STRICT;
> -bborie
> On 02/22/2012 12:16 PM, Stephen Crawford wrote:
>> Tried running it and get this:
>> "ERROR: function _st_summarystats(raster, integer, boolean, integer) is
>> not unique
>> LINE 3: AS $$ SELECT _st_summarystats($1, 1::int, $2, 1) $$
>> HINT: Could not choose best candidate function. You might need to add
>> explicit type casts"
>> -Steve
>> On 2/22/2012 1:59 PM, Bborie Park wrote:
>>> Interesting. Can you run the following and try again?
>>> If that removes the HINT, I'll make the appropriate changes to the code.
>>> -bborie
>>> On 02/22/2012 10:48 AM, Stephen Crawford wrote:
>>>> I only tried the casting because of the messages I get, on of which is:
>>>> "function _st_summarystats($1, 1, $2, 1) is not unique"
>>>> and
>>>> "HINT: Could not choose best candidate function. You might need to add
>>>> Thanks,
>>>> steve
>>>> On 2/22/2012 1:41 PM, Bborie Park wrote:
>>>>> Hey Steve,
>>>>> _st_summarystats is an underlying function that isn't meant for use by
>>>>> end-users. ST_SummaryStats is what you should be using.
>>>>> The example query you provided shouldn't have any issues and shouldn't
>>>>> be creating any of those messages. In your situation, you don't even
>>>>> need the true::boolean.
>>>>> -bborie
>>>>> On 02/22/2012 10:34 AM, Stephen Crawford wrote:
>>>>>> Should I have both _st_summarystats and st_summarystats in my
>>>>>> database?
>>>>>> I get messages like "function not unique" and "could not choose best
>>>>>> candidate function" when doing this:
>>>>>> SELECT rid, observation_date, ST_SummaryStats(rast::raster,
>>>>>> true::boolean) FROM spring_ms WHERE observation_date = '2012-02-20';
>>>>>> I expected to get 187 records (one for each tile).
>>>>>> Thanks,
>>>>>> Steve
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
> ______________________________**_________________
> postgis-users mailing list
> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120222/33e487eb/attachment.html>
