[postgis-users] extra function?
Stephen Crawford src176 at psu.edu
Wed Feb 22 13:45:50 PST 2012
Thanks for the help everybody.  I'll look into it tomorrow.
On 2/22/2012 4:39 PM, John Callahan wrote:
> Steve,
> I had a similar issue.  If you look at your list of functions (say
> through pgAdmin), you'll probably see multiple instances of that
> function.  If the same function is listed more than once, with the
> same number and type of arguments, then it will (I think?) report as
> not unique.  In that case, I manually deleted the duplicate functions,
> and then added them back.  To add them back, look inside the
> rt_postgis.sql (or postgis.sql) file than comes with the distribution
> (I'm using alpha5).  you'll see all of the functions in there.  Just
> cut and paste the necessary CREATE OR REPLACE statements for your
> functions into the Query Tool or psql console window.
> - John
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> On Wed, Feb 22, 2012 at 4:28 PM, Bborie Park <bkpark at ucdavis.edu
> <mailto:bkpark at ucdavis.edu>> wrote:
>     Steve,
>     I know enough to do my own testing and make the necessary changes.
>     Until I have the time to do so, the following should work.
>     CREATE OR REPLACE FUNCTION st_summarystats(rast raster,
>     exclude_nodata_value boolean)
>     RETURNS summarystats
>     AS $$ SELECT _st_summarystats($1, 1, $2, 1.) $$
>     LANGUAGE 'SQL' IMMUTABLE STRICT;
>     -bborie
>     On 02/22/2012 12:16 PM, Stephen Crawford wrote:
>         Tried running it and get this:
>         "ERROR: function _st_summarystats(raster, integer, boolean,
>         integer) is
>         not unique
>         LINE 3: AS $$ SELECT _st_summarystats($1, 1::int, $2, 1) $$
>         HINT: Could not choose best candidate function. You might need
>         to add
>         explicit type casts"
>         -Steve
>         On 2/22/2012 1:59 PM, Bborie Park wrote:
>             Interesting. Can you run the following and try again?
>             If that removes the HINT, I'll make the appropriate
>             changes to the code.
>             -bborie
>             On 02/22/2012 10:48 AM, Stephen Crawford wrote:
>                 I only tried the casting because of the messages I
>                 get, on of which is:
>                 "function _st_summarystats($1, 1, $2, 1) is not unique"
>                 and
>                 "HINT: Could not choose best candidate function. You
>                 might need to add
>                 Thanks,
>                 steve
>                 On 2/22/2012 1:41 PM, Bborie Park wrote:
>                     Hey Steve,
>                     _st_summarystats is an underlying function that
>                     isn't meant for use by
>                     end-users. ST_SummaryStats is what you should be
>                     using.
>                     The example query you provided shouldn't have any
>                     issues and shouldn't
>                     be creating any of those messages. In your
>                     situation, you don't even
>                     need the true::boolean.
>                     -bborie
>                     On 02/22/2012 10:34 AM, Stephen Crawford wrote:
>                         Should I have both _st_summarystats and
>                         st_summarystats in my
>                         database?
>                         I get messages like "function not unique" and
>                         "could not choose best
>                         candidate function" when doing this:
>                         SELECT rid, observation_date,
>                         ST_SummaryStats(rast::raster,
>                         true::boolean) FROM spring_ms WHERE
>                         observation_date = '2012-02-20';
>                         I expected to get 187 records (one for each tile).
>                         Thanks,
>                         Steve
>     Bborie Park
>     Programmer
>     Center for Vectorborne Diseases
>     UC Davis
>     530-752-8380 <tel:530-752-8380>
>     bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at postgis.refractions.net
>     <mailto:postgis-users at postgis.refractions.net>
>     http://postgis.refractions.net/mailman/listinfo/postgis-users
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
src176 at psu.edu
814.865.9905
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120222/d9cfdd8b/attachment.html>
