[postgis-users] st_geomfromkml problem
Paragon Corporation
lr at pcorp.us
Fri Feb 24 04:41:53 PST 2012
Ahmad,
The question I have for you is why you have your srid as -1.
KML spatial_ref is ALWAYS 4326 so I expect any ST_GeomFromKML to come back
as srid = 4326. You can't create a KML file that is not 4326 (WGS 84) as I
recall. If you were able to in the past,
then that's a mistake and perhaps that was corrected in 2.0.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Sandro Santilli
> Sent: Friday, February 24, 2012 3:13 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] st_geomfromkml problem
> On Thu, Feb 23, 2012 at 09:17:11PM -0500, Ahmad Aburizaiza wrote:
> > So the table has a geom column and a column to store the KML text
> > besides name and id. I want the geom field to store a
> polygon from the KML column.
> > So first I inserted id, name, and KML as text and geom as
> NULL. Than I
> > ran the below update SQL statement:
> > *Update table1 set geom
> st_geomfromkml('<Polygon><outerBoundaryIs><LinearRing><coordinates>39.
> > 788212,21.424540 ........
> 39.788212,21.424540</coordinates></LinearRing></outerBoundaryIs></Poly
> > gon>');
> > But an error appears that this conflicts with
> > *enforce_srid_geom*constraint. I removed it and I was able
> to update
> > the geom column but it really does not make sense. The geom I am
> > trying to insert does not conflict with the constraints. I
> created the
> > kml polygon in Google Earth and the srid for that is -1.
> Please help
> Did you upgrade from 1.x to 2.0 ?
> If you did you probably did it too early, or not using the
> correct method (hard upgrade).
> In 2.0 any negative SRID gets converted to 0 so you'll never
> meet the check for -1. The hard upgrade procedure updates
> that constraint.
> --strk;
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.0 !
> | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> `-o------'
> postgis-users mailing list
