[postgis-users] st_geomfromkml problem
Ahmad Aburizaiza ahmadoa4 at gmail.com
Fri Feb 24 19:47:52 PST 2012
Thanks a lot to both of you. I changed the SRID to 4326 and it is working.
Ahmad Aburizaiza
PhD student at George Mason University
Geography and Geoinformation Science Department
Fairfax, VA, USA
Tel : +1-703-981-0354*
On Fri, Feb 24, 2012 at 7:41 AM, Paragon Corporation <lr at pcorp.us> wrote:
> Ahmad,
> The question I have for you is why you have your srid as -1.
> KML spatial_ref is ALWAYS 4326 so I expect any ST_GeomFromKML to come back
> as srid = 4326.  You can't create a KML file that is not 4326 (WGS 84) as I
> recall.  If you were able to in the past,
> then that's a mistake and perhaps that was corrected in 2.0.
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of Sandro Santilli
> > Sent: Friday, February 24, 2012 3:13 AM
> > To: PostGIS Users Discussion
> > Subject: Re: [postgis-users] st_geomfromkml problem
> > On Thu, Feb 23, 2012 at 09:17:11PM -0500, Ahmad Aburizaiza wrote:
> > > So the table has a geom column and a column to store the KML text
> > > besides name and id. I want the geom field to store a
> > polygon from the KML column.
> > > So first I inserted id, name, and KML as text and geom as
> > NULL. Than I
> > > ran the below update SQL statement:
> > > *Update table1 set geom
> > st_geomfromkml('<Polygon><outerBoundaryIs><LinearRing><coordinates>39.
> > > 788212,21.424540 ........
> > 39.788212,21.424540</coordinates></LinearRing></outerBoundaryIs></Poly
> > > gon>');
> > > But an error appears that this conflicts with
> > > *enforce_srid_geom*constraint. I removed it and I was able
> > to update
> > > the geom column but it really does not make sense. The geom I am
> > > trying to insert does not conflict with the constraints. I
> > created the
> > > kml polygon in Google Earth and the srid for that is -1.
> > Please help
> > Did you upgrade from 1.x to 2.0 ?
> > If you did you probably did it too early, or not using the
> > correct method (hard upgrade).
> > In 2.0 any negative SRID gets converted to 0 so you'll never
> > meet the check for -1. The hard upgrade procedure updates
> > that constraint.
> > --strk;
> >   ,------o-.
> >   |   __/  |    Delivering high quality PostGIS 2.0 !
> >   |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
> >   `-o------'
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120224/74dd1eb3/attachment.html>
